Temp Gauge doesn't work - JeepForum.com
post #1 of 3 Old 10-01-2013, 09:02 PM Thread Starter
ksufootball44
1977 CJ7
I just replaced the fuel and temp gauges, fuel sending unit and temp sensor and now everything works except the temp gauge. I followed John Shrenk's troubleshooting document but I still can't figure out the issue.
Testing results:
Temp gauge =
1. "A" to "S" = 21ohms
2. light flashes testing temp sending unit
3. grounding sending unit doesn't make my temp gauge rise at all
Fuel gauge =
S to ground= 17 not 68 to 72
S to I = 19 - 21
S to A = 19 - 21
I to A = 0
I to ground = 17 not 49 - 51
A to ground = 17 not 49 - 51
**i have a ground wire from the speedometer to the - on the battery
ksufootball44 is offline
post #2 of 3 Old 10-02-2013, 03:05 AM
BagusJeep
1981 CJ7
HAve you tried grounding the terminal on the back that goes to the temp sending unit? Does it then move?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 3 Old 10-02-2013, 09:13 AM Thread Starter
ksufootball44
1977 CJ7
Sorry, I wasn't using a ground wire, I was using my test light as my ground wire. Once I grounded the temp gauge, it started to move.
Resistance measurement Temperature Sensor
Question- When I take my ohmmeter and connect one lead to ground and the other lead to the post on the temp sensor, I'm not getting any reading. (I should be getting at least 200 to 400 ohms at room temp). Does this mean my new temp sensor is bad? Also, if I remove my temp sensor to perform more test, how do you keep the coolant from running out?
