Temp/Fuel Gauges - JeepForum.com
post #1 of 10 Old 04-24-2010, 07:13 PM Thread Starter
adman02
1979 CJ7
Temp/Fuel Gauges
I've been trying to figure out why my gauges aren't working. I've worked through John Strenk's gauges write-up, but I'm not sure what the results tell me. Here are my numbers:
Fuel
S to Grnd - 36.4 ohms
S to I - 21.6 ohms
S to A - 21.4 ohms
I to A - .6 ohms
I to Grnd - 15.6 ohms
A to Grnd - 15.2 ohms
Temp
S to A - 6 ohms
Fuel sender
64 ohms (tank is pretty low right now)
Am I right in concluding that my fuel sender is fine, but my fuel and temp gauges are toast?
adman02 is offline
post #2 of 10 Old 04-25-2010, 01:13 AM
samini
I got readings close to the same when going through my brand new gauges, went through all the trouble shooting as described be strenk and finally found out that the little dimples (grounds for the gauges) on the speedometer housing were not quite grounding. I discovered this because I scrapped them with a screwdriver and cleaned them up with a wire brush and viola! it all worked. Try that! and hopefully it works.
1984 CJ7 4.2 L 258 Motorcraft 2100 Carb Nutter Bypass Done
samini is offline
post #3 of 10 Old 04-25-2010, 06:50 AM Thread Starter
adman02
1979 CJ7
Are the dimples you're talking about located inside the speedo cluster? I haven't taken mine apart, but did pull the unit out and clean up the outside with a brass brush. Then I ran a dedicated ground to the cluster. No change. Gauges still unresponsive.
adman02 is offline
post #4 of 10 Old 04-25-2010, 09:45 AM
brian613
1977 CJ5
the fuel gauge grounds through the speedo cluster by touching the speedo case. if the back of the fuel gauge is gunked up it wont ground. id put more fuel in the tank then take the speedo cluster apart remove the fuel gauge and clean the back of the gauge (in between the bolts) and then clean the inside of the speedo cluster where the fuel gauge touches
brian613 is offline
post #5 of 10 Old 04-25-2010, 07:24 PM Thread Starter
adman02
1979 CJ7
Tore everything down, cleaned it (again) and put it back together again. Found a short in the system and diagnosed a bad temp sender. Rechecked my numbers and they now read:
Fuel
S to Grnd - 72.4 ohms
S to I - 21.5 ohms
S to A - 21.2 ohms
I to A - .4 ohms
I to Grnd - 51.1 ohms
A to Grnd - 51.1 ohms
Temp
S to A - 21.2 ohms
Put five gallons of gas in my 15 gallon tank, but the fuel gauge barely climbs to E. Now I'm thinking my fuel sender is bad. Any thoughts?
adman02 is offline
post #6 of 10 Old 04-26-2010, 09:13 PM
samini
Where was your short in the system? Did you do the Stenk diagnostics on the sender?
samini is offline
post #7 of 10 Old 04-27-2010, 04:33 AM Thread Starter
adman02
1979 CJ7
Short was in one of two places
  1. Wire strands in the fuse box left over from a PO's "repair" job
  2. Missing bulb in the speedo cluster (wire that goes to the base of the bulb I think may have been shorting the circuit)
Haven't done the Strenk sender diagnostics because I can't reach the top of the fuel tank (no body lift on my jeep).
I have run dedicated grounds, so I'm pretty certain the system is grounded well. The sender is the only thing I haven't checked.
adman02 is offline
post #8 of 10 Old 04-27-2010, 06:21 AM
ctm
If your gauge "barely climbs to E" then it is functioning but not accurate. I had my gauges out a while back and I remember there are mechanical adjustments you can make. One or both of the gauges has a slot for a small screwdriver so you can move the needle to where you think it should be. If you don't see an adjustment you can always pull the needle off and move it a bit to be accurate. It may take several tries to get it right. I would start with 1/2 tank or a full tank of gas and go from there.
ctm is offline
post #9 of 10 Old 05-02-2010, 07:29 PM Thread Starter
adman02
1979 CJ7
Dropped the tank today to replace the sender and found out why the old one wasn't working...the float was half full of fuel. Sort of surprised as the float was brass and I couldn't really see any holes in it.
The new sender has a spongey foam float, so little risk of it filling with gas.
adman02 is offline
post #10 of 10 Old 05-03-2010, 02:11 AM
pazur
1981 CJ7
I don't like I to A .6 ohms. There should be no resistance when there is no current supplied to I. You may have sticked or nearly sticked contacts in the "voltage" regulator. correct me if I am wrong.
pazur is offline
CJ5 Fuel/Temp gauges nickgbb Jeep CJ Forum 6 04-07-2008 12:56 PM
Fuel and Temp Gauges Gart79CJ Jeep CJ Forum 4 08-17-2006 06:14 PM
fuel & temp. gauges guilloejeep Jeep CJ Forum 4 04-26-2006 10:16 AM
fuel & temp. gauges guilloejeep Jeep CJ Forum 1 04-24-2006 09:56 PM
fuel and temp gauges also boydog40 Jeep CJ Forum 2 02-13-2005 08:59 PM
