tell me what you think about the new project - Page 2 - JeepForum.com
post #16 of 307 Old 11-27-2010, 09:17 PM
SKT
Looks great, keep us posted w/ updates!
SKT is online now
post #17 of 307 Old 11-27-2010, 10:05 PM Thread Starter
cjdogtoy
1976 CJ5
the plans are to replace the tie rod, fab some good bumpers with a swing out tire carrier on back to get all that weight of the back of the body. rebuild the rear drive shaft, replace the coolant reservoir. u-pol raptor the inside black and the outside clear color matched to the bug next to it, then on component at a time replace every seal on the jeep.
cjdogtoy is offline
post #18 of 307 Old 11-27-2010, 10:09 PM Thread Starter
cjdogtoy
1976 CJ5
by the way this is the car I traded to get the jeep and tool box/ 93 honda del sol with custom body work
cjdogtoy is offline
post #19 of 307 Old 11-28-2010, 05:09 AM
adman02
1979 CJ7
Sorry to hijack, but my drive shaft looks the same as yours. How bad/dangerous is a DS in this condition? I suspect mine is due to my 4 in lift. What;s the best way to fix this and prevent it in the future?
adman02 is online now
post #20 of 307 Old 11-28-2010, 09:51 AM Thread Starter
cjdogtoy
1976 CJ5
my ds has probably been that way for a while and what has happened is dirt gets into the slip joint and it wares really bad, that makes it loose and sloppy, which then allows it to spin out of balance, which causes vibration and extra were on u-joints and yokes. if not replaced or rebuilt it will ultimately fail when going down the road, if it brakes at the back it will just spin around tearing up the entire back of the jeep(think big hammer spinning like weed eater) if it breaks up front it will also spin around and destroy everything in reach but just for fun if it hits the ground while you are still moving forward the entire jeep gets shot into the air (think pole vault at 55mpr. been know to total vehicles and kill people) hope that explains it I personally plan on replacing it not rebuilding it once the slip joint is worn the metal is gone and it will never be rite.
cjdogtoy is offline
post #21 of 307 Old 11-28-2010, 07:47 PM Thread Starter
cjdogtoy
1976 CJ5
didn't get much time to wok on the jeep today so I didn't get allot done, but here it is.
replaced coolant overflow bottle
replaced heater hoses
changed oil
flushed coolant(look how pretty green it is)
tightened valve cover
replaced the belt
replaced the air filter
just got the engine compartment up to date on allot of maintenance
I'll be back at it tomarrow
cjdogtoy is offline
post #22 of 307 Old 11-28-2010, 07:53 PM
Jim1611
Jim1611's Avatar
It's not taking you long to dive into this one.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #23 of 307 Old 11-28-2010, 08:06 PM
Skerr
I can see a guy selling his Jeep... but his tools?? Wow....
Kerrdog
Go Fish! <*////><
Skerr is offline
post #24 of 307 Old 11-28-2010, 08:11 PM
jeepcj258
1980 CJ5
I like the 5!
jeepcj258 is offline
post #25 of 307 Old 11-28-2010, 08:39 PM
73jeep
1973 CJ5
For a honda de sol.........
73jeep is offline
post #26 of 307 Old 11-30-2010, 10:14 PM Thread Starter
cjdogtoy
1976 CJ5
yesterday I decided to check the brakes and I'm glad I did. The po did the lift but didn't replace the brake lines with the longer ones I found that they were cracked and leaking from being over extended here's the old one
I spent most of the day finding replacements the only place that had them was napa but they wanted 35.99 for one at the stock length and would have to order the longer ones. then I found a shop called parker that fabbed them while I waited, and the total bill was only 37.00
cjdogtoy is offline
post #27 of 307 Old 11-30-2010, 10:18 PM Thread Starter
cjdogtoy
1976 CJ5
today all I got done was ordering the new rear drive shaft. I should be able to pick it up tomorrow.
cjdogtoy is offline
post #28 of 307 Old 11-30-2010, 10:45 PM
benullman
1981 CJ7
you mentioned replacing all the seals. Thats a hell of an undertaking. I planned on it and figured I could do it in 2 weeks. replacing every seal/gasket in my motor except the head. I am down to the oil pan and valve cover getting paint and put back on this weekend. Then reassemble PS pump and put the pulleys on. Replace the manifolds and put a newly rebuilt weber on.
I can try and provide a list of all the gaskets I used for mine if you would like.
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #29 of 307 Old 12-01-2010, 05:57 AM
brownbagg
1930 MK Compass
you could replace all the seal except for the rear main in about 45 minutes not talking about axles and transmission
brownbagg is offline
post #30 of 307 Old 12-01-2010, 06:00 AM
benullman
1981 CJ7
Id LOVE to se that. Granted I painted everything and I did it section by section it will still take you atleast a weekend.
Ben
Looking for a project? adman02 Jeep CJ Forum 1 08-20-2009 08:58 PM
Project Tub Swap... then Project Moab certifiablejeep Jeep CJ Forum 9 08-04-2009 11:38 AM
New Cj5 Project!! dbarnhart4 Jeep CJ Forum 3 04-25-2009 11:33 AM
Project Reassembly has inspired my project WHAT THE HECK WAS I THINKING jcooley7 Jeep CJ Forum 5 05-28-2008 05:53 AM
81 CJ7 Project BeesJeep Jeep CJ Forum 8 12-16-2007 09:08 AM
