Tell me about Spools. - JeepForum.com
post #1 of 24 Old 07-14-2010, 02:45 PM Thread Starter
crzdmnky
1978 CJ5
So tell me about spools. I am in the process of building a CJ5 mainly for the trails but am looking for some street driveability. I just got the Clutch in last night and took it out this morning.
It has a limited slip in the rear and it seemed tight up on the lift, but man when I tried to take it up my test course this jeep is the biggest dog of them all. It just sat there and spun its two passenger side tires (front and rear). I am a believer of the lunchbox lockers, but the price of the spools is very attractive.
I have read what I can on this subject, but everything I read was pretty old, just wondering if there is a new consensus.
Can you rebuild Limited slips?
IE. AMC20 rear Dana30 front
crzdmnky is offline
post #2 of 24 Old 07-14-2010, 02:49 PM
82JeepCJ7
1982 CJ7
I'm running a spool in the rear of my CJ7. I love it. It is very predictable, strong, simple and inexpensive. Sure, turning in parking lots draws attention (bark bark bark bark) but its not a pavement pounder. Throw a lunch box locker in the front, spool the rear and call it good. One nice thing about a spool on the road, if the rear tires are the same psi, is that it will track very strait. Wont wonder around.
82JeepCJ7 is offline
post #3 of 24 Old 07-14-2010, 02:53 PM
scooby533
The limited slips are very much rebuild-able. An AMC 20 trac loc disc kit goes for 60$ give or take. I don't think they put out a D30 w/ limited slip from the factory???? Someone else may be able to answer that. The discs aren't very hard to replace. 4WD hardware or Quadratec both have the kit as do others for a better price I'm sure.
scooby533 is offline
post #4 of 24 Old 07-14-2010, 03:11 PM Thread Starter
crzdmnky
1978 CJ5
Well, I own two CJs, so i was thinking of taking the limited slip out of my CJ5 and rebuilding it and installing it in my CJ7 DD. Then taking my carrier from my CJ7 and putting some type of locker in it and installing it into my CJ5. I just dont know what I want to do. They dont offer spools for AMC20's, so welding it is the only option or lunch boxing it.
crzdmnky is offline
post #5 of 24 Old 07-14-2010, 03:21 PM
kcarlsonjeep
1979 CJ5
I'm running a spool in the rear of my Cj5. It is definitely predictable on the street. Wouldn't recommend it for an everyday driver but once and a while on the street it is alright. Awesome on the trail. Very strong and dependable.
kcarlsonjeep is offline
post #6 of 24 Old 07-14-2010, 03:22 PM
kcarlsonjeep
1979 CJ5
Yeah sorry not available for a amc 20.
post #7 of 24 Old 07-14-2010, 03:23 PM
howelljeep
1979 CJ5
Is there a difference between a spool and welding the spider gears?
1982 CJ8
1979 CJ5 258 I6 3 speed
1999 Dodge Durango
howelljeep is offline
post #8 of 24 Old 07-14-2010, 03:35 PM Thread Starter
crzdmnky
1978 CJ5
No difference, just a spool is cleaner and doesnt require any prep work or whatever you want to call it.
crzdmnky is offline
post #9 of 24 Old 07-14-2010, 04:45 PM
ReconRabbit
1983 CJ7
They make spools for amc 20's, I've seen them many times
If your Jeeps not leaking it's out of fluids.
ReconRabbit is offline
post #10 of 24 Old 07-14-2010, 04:50 PM Thread Starter
crzdmnky
1978 CJ5
Are they any cheaper than a locker? I remember seeing them for other rearends for around $70
crzdmnky is offline
post #11 of 24 Old 07-14-2010, 05:20 PM
SeaWulf
1983 CJ7
When you weld the rear spiders, you call it a lincoln locker.
Keep in mind that if you weld the spiders, you also need to weld them to the carrier.
Mini-spools just replace the spiders, so you can pull it and go back to stock. A full spool replaces the whole carrier.
From personal experience, I'd say that running MT tires on the street is better. They don't grab the pavement as much as ATs will, making less noise, hopping less (the rear end will bounce because the tires are dragging), and tightening the steering radius.
Offroad, you'll notice the difference right away, and there's really no downfalls.
SeaWulf is offline
post #12 of 24 Old 07-14-2010, 05:43 PM Thread Starter
crzdmnky
1978 CJ5
Alright man, thanks, still looking for either a full spool or a mini-spool. I dont really want to ruin a perfectly good carrier and spider gears. Anyone have any ideas?
crzdmnky is offline
post #13 of 24 Old 07-14-2010, 07:33 PM
ReconRabbit
1983 CJ7
I don't think they make a mini spool for a 20. It looks like just a full spool. Here's a like to one at Randy's
AMC Model 20 Differential Spools & Mini-Spools Auto Parts: YUKON GEAR,YUKON AXLE,YUKON,SPOOL,MODEL 20,FULL SPOOL,DIFFERENTIAL,CJ,AMC 20,YP FSM20-3-29,
post #14 of 24 Old 07-14-2010, 09:07 PM Thread Starter
crzdmnky
1978 CJ5
That is not feasible to buy, I can get a lunchbox locker for that much. Well, hmmm.
crzdmnky is offline
post #15 of 24 Old 07-15-2010, 07:49 AM
82JeepCJ7
1982 CJ7
I wouldn't bother with rebuilding a limited slip. You will still be stuck with one wheel spinning when you need traction the most. Before I swapped the Dana 60 into the CJ7, I welded up the spiders on my trac-lok. I pulled the carrier out, cleaned the diff in the parts washer, then in a bucket of dish washing soap/water. After that I put it in the oven on an old cookie sheet @ 250 for about an hour. After that I ran it through the dish washer on "pots and pans" to remove any oils that were baked out of the pours of the cast steel. (Don't tell the wife )
After that, I put the diff back in the oven to pre-heat while I went out and got the welder set up in the shop. After pre-heating I took the diff out to the shop and welded the spider gears and gears to the case with E309L (stainless). The 309L is very resistant to cracking due to vibration and bonds well to cast.
detroit , limited slip , locker , mini spool , posi , spool , spools
Spools, Lockers and Limited Slips emersonjeep Jeep CJ Forum 13 02-23-2006 12:07 PM
Mini-Spools jpfaris Jeep CJ Forum 1 02-17-2006 02:09 PM
Spools on the street Moxj85 Jeep CJ Forum 5 06-13-2002 09:35 PM
