Tell me about Dana 44's with 10 Spline axles - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Tell me about Dana 44's with 10 Spline axles
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Cure for your Tie Rod Roll!Offset Tie Rod Kit From RuffStuff!
Unread 06-02-2013, 06:25 AM   #16
jp360cj
1977 CJ7
It will bolt in, but will probably be wide track. Your CJ5 came with narrow track. You also need to check the gear ratios and make sure they are the same. WTs have shock mounts on the axle tube, NTs have them on the u bolt plate. Use your NT u bolt plate and bolt the shocks to them. And if the rear has 2 piece axles you'll want to put a 1 piece kit in
If the CJ7 has both axles and they are in decent shape, I would swap both out. You can swap your brake stuff over, its probably in better shape than one that's been sitting. I would also swap the hubs on the front. Your 78 will have the stronger 6 bolt hubs vs the 5 bolt on the 85
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is online now   Reply With Quote Quick reply to this message
Unread 06-03-2013, 11:32 AM   #17
imnanas
1979 CJ5
Thanks so much for getting back to me so fast. I don't really fancy her wheels being that much farther out. Will investigate, probably a replacement housing for me.
imnanas is offline   Reply With Quote Quick reply to this message
10 spline , 30 spline , course spline , dana 44 , Dana 44 axle shafts
