Tell me about Dana 44's with 10 Spline axles - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Tell me about Dana 44's with 10 Spline axles
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 07-20-2010, 09:28 PM   #1
crzdmnky
1977 CJ5
I have a Dana 44 with the 10 spline axles in it. Is there anything I can do with this rearend other than sale it for scrap? Is it any worse off than a regular D44? It would be a direct bolt in into my 77 CJ5.
crzdmnky is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 09:32 PM   #2
crzdmnky
1977 CJ5
I might be ahead of myself. the front end I have which is a Dana 27? has 10 spline axles, dunno about the Dana 44. Got in a hurry perhaps.
Unread 07-20-2010, 09:54 PM   #3
brownbagg
1930 MK Compass
those are axle off an early jeep like 65 and earlier. postal jeeps had 10- spline 44
brownbagg is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 09:56 PM   #4
crzdmnky
1977 CJ5
Eh? Desirable?
Unread 07-20-2010, 10:45 PM   #5
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Originally Posted by crzdmnky View Post
Eh? Desirable?
Don't see why they would be, but you never know what people are looking for.
Heck, look at how much old Chrysler junk is going for at auctions now....more than any GM or Ford stuff, and Chrysler stuff was always a distant 3rd back in the day. (just like now)
I can't believe how much Hemi Cudas and all go for.....these were cool cars, but never were thought of the way they are now until really, this decade.
Pacfanweb is offline   Reply With Quote Quick reply to this message
Unread 07-21-2010, 03:33 AM   #6
Eman
sell it on craigslist if you dont want it, people around here still buy'em for willys projects ect. atleast its not a timken two half rear end
89' Jeep Cherokee Laredo - Rough Country 4.5" Full leaf pack.
55' 4x4 Willys Wagon
- Restoration Project
Eman is offline   Reply With Quote Quick reply to this message
Unread 07-21-2010, 05:45 AM   #7
Mister 4x4
1980 CJ5
Why not upgrade the shafts to a higher spline count???
Mister 4x4 is offline   Reply With Quote Quick reply to this message
Unread 07-21-2010, 06:54 AM   #8
colojeepguy
1970 CJ5
What's this axle out of? the only 10 spline 44's I know of are from early cj's which won't fit yours (offset vs center diff.)
colojeepguy is offline   Reply With Quote Quick reply to this message
Unread 07-21-2010, 09:11 AM   #9
CSP
Maybe really old ones did, but the DJ received 30 spline Dana 44s about the same time that CJ's did.
The only '77 CJ that the subject axle would bolt into would be a CJ7 with Quadratrac. No CJ5's came with Qtrac, so it isn't a bolt in for a 77 CJ5.
CSP is offline   Reply With Quote Quick reply to this message
Unread 07-21-2010, 03:47 PM   #10
crzdmnky
1977 CJ5
Got to looking more closely at the rearend last night. It has one piece axles, and a centered differential. So maybe its out of a 72' and later CJ. It appears to be 30 spline, but the front end that came along with this rear end when I received it was a Dana 27 with 10 splines. O'well, I think I am going to build this Dana 44 and hopefully I wont run into any problems.
It has 3.73 gears, narrow track
Put some wheel spacers on it to equal the a widetrack axle, because I am going to have to perchase some 3.73 gears for a Dana 30 front end, and I might as well put the Widetrack I have sitting in my shop in it, and build it. I am a firm believer in widetrack axles.
Unread 07-21-2010, 04:18 PM   #11
CSP
If it's centered with flanged axleshafts, it's a 72-75 and 30 spline.
Unread 07-21-2010, 07:20 PM   #12
jp360cj
1977 CJ7
Just pull a shaft out and count the splines, but it does sound like a 72-75 30 spline
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline   Reply With Quote Quick reply to this message
Unread 07-21-2010, 10:25 PM   #13
80cj
80cj's Avatar
1980 CJ5
Flanged axle shafts will be 30 spline. You can pull the cover and look at the differentail side gears. It would also give you a chance to assess the condition of the internals at the same time. A 72-75 CJ-5 or Commando 44 will have 50.5" WMS dimension, same as NT AMC 20.
80cj is offline   Reply With Quote Quick reply to this message
Unread 06-02-2013, 06:58 AM   #14
imnanas
1979 CJ5
This is the closest thread I could find to ask this question. I have a 79 cj5. The PO burned up rear drivers side wheel bearing so bad that it welded the bearing to the axel shaft & chewed the crap out of the axel housing, where the bearing cup sits. We replaced axel shaft & bearing, tried industrial lock tight, hoping it would hold the bearing where it is. Nope, it let go. We also have a 85? Cj7 frame. They both look to be AMC 20s. What do I have to do, except measure to see if this will fit my cj5? I have 35" tires, 3" lift on the 5.
imnanas is offline   Reply With Quote Quick reply to this message
Unread 06-02-2013, 07:11 AM   #15
Al_77cj5
1977 CJ5
check the gearing to see if it matches your cj5, the 85 axles will be wide track. If you have both axles I would swap them both into your cj5. they will bolt right in and be 3 or so inches wider. but if the gearing is not desirable you may want to get your gears swapped over to the 85 housings.
97 tj wrangler, 77 cj5, 78 cj7, 76 j10, 53 cj3b, 81 amc eagle wagon
Al_77cj5 is offline   Reply With Quote Quick reply to this message
10 spline , 30 spline , course spline , dana 44 , Dana 44 axle shafts
