Tech4 swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Tech4 swap
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 07-22-2015, 02:01 PM   #1
dls1955
1981 CJ5
Tech4 swap
Has anyone replaced the regular iron Duke(81) with a tech4 Iron Duke? Looks like an easy swap to me.
dls1955 is offline   Reply With Quote Quick reply to this message
Unread 07-22-2015, 02:49 PM   #2
Always2L8
1982 CJ8
First thing that comes to mind ........ different bell housing pattern. Jeep 151 = SBC V8 pattern, Tech 4 151 = BOP / Metric / 60 deg pattern.
Probably the biggest advantage is the fuel injection, but don't think there's a real gain in Torque or HP.
Good Luck
Always2L8 is offline   Reply With Quote Quick reply to this message
Unread 07-23-2015, 12:01 PM   #3
dls1955
1981 CJ5
Thanks 2L8. Do you know if the bell housing off the older 151 will fit the Tech4? HP goes from 82 to 98. Not sure about torque.
Unread 07-23-2015, 01:45 PM   #4
Partsmke
Camaro bell housing that used the 3800 engine with a T5 will accept the SR4/T4/T5 transmissions and bolt up to the later 4 cylinder engines.
Partsmke is offline   Reply With Quote Quick reply to this message
Unread 07-23-2015, 02:13 PM   #5
dls1955
1981 CJ5
Thanks partsmke. The tech4 is in an 87 s10 right now so it's inline. I'll find out if they stayed with the 60deg. housing even though it's not FWD once I get it out where I can see it. I'm thinking this is doable without a lot modification. Thanks for the info. Good stuff to know.
Unread 07-24-2015, 09:34 AM   #6
Partsmke
The Tech 4 has the same bell housing configuration as the 2.8 V6 which is the small pattern like the 3800 I mentioned.
Unread 07-24-2015, 09:48 AM   #7
Always2L8
1982 CJ8
The bell housing from an AMC 2.5L (BOP-60) should work on the Tech 4. Came with 84 to 86 CJ's. But I don't have first hand experience with that.
Good Luck
Unread 07-24-2015, 11:21 AM   #8
captkhaos
1980 CJ7
Put a cam and header on your 151. Different carb on a tech 4? Get a Weber. I put a cam in my 151 and it became a whole new Jeep. Pulled smooth to 5K+. Finally threw a rod. Get a 258 if you really want more power. Then put a cam and header on it!
captkhaos is offline   Reply With Quote Quick reply to this message
Unread 07-24-2015, 02:36 PM   #9
dls1955
1981 CJ5
So the original Bellhousing is with it. Does anyone know if this will bolt up to my SR4 trans. It had a four speed( 2WD) behind it originally when it was in the S10.
Unread 07-24-2015, 03:10 PM   #10
Partsmke
Check the bolt pattern for the transmission, GM used a different pattern than Jeep and Ford.
