teamrush upgrade on 77 jeep with breaker points - JeepForum.com
post #1 of 3 Old 08-28-2008, 11:01 PM Thread Starter
89s15
i am new to this and have searched but cant find out how to do a teamrush upgrade on a 77 cj5 with a 304 v8 and points distributor i would apprciate all the help i could get
89s15 is offline
post #2 of 3 Old 08-28-2008, 11:38 PM
JeepHammer
Running On Empty...
1973 CJ5
Welcome to the forum!
First off, if you have a Prestolite ignition, (Check for plastic vacuum advance canister on the distributor), there is NO upgrade available.
Prestolite was factory from '74 to '77 on CJ's with both I-6 and V-8 engines.
If you have an aluminum housing on a 'Breaker Points' distributor, it's a Delco Remy distributor, and any 'Electronic Conversion' kit that will work for a Camaro will work for you.
If you do it yourself, you are looking at $15 in off the shelf parts.
If you buy the conversion kit, you are looking at $60 to $100.
Here is how I did mine,
http://www.junkyardgenius.com/jeep/cj502.html
http://www.junkyardgenius.com/jeep/cj503.html
http://www.junkyardgenius.com/jeep/cj503a.html
MSD makes a 'Cap-A-Dapt' that will give you the large Ford type cap, better rotor, and will accept good plug wires.
Cap, rotor and plug wires will run you about $100.
http://store.summitracing.com/partde...5&autoview=sku
What I would do if I were you,
For around $60 you can get a Jeep/Motorcraft distributor reman from the parts stores.
I would put the large cap, rotor and good plug wires on it,
And I would use a CDI (Capacitive Discharge Ignition) module to trigger a factory style coil...
Any questions?
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #3 of 3 Old 08-29-2008, 11:01 PM Thread Starter
89s15
thank you so much that is everything i need now jus have to go look at the distibutor in the morning i apprciate everything
89s15 is offline
I-6 'TeamRush Upgrade' (definitive) JeepHammer Jeep CJ Forum 732 03-24-2017 12:11 PM
Prestolite to teamrush upgrade- Amc 360 v8 2manytoys2 Jeep CJ Forum 13 10-26-2012 12:16 PM
TEAMRUSH Upgrade, Who SELLS PLUG WIRES?? Fjguercio Jeep CJ Forum 14 06-02-2010 08:16 PM
What is a TeamRush upgrade ? tevans59 Jeep CJ Forum 6 01-11-2010 06:02 PM
Teamrush upgrade on 76 CJ5 76silvercj5 Jeep CJ Forum 9 08-26-2008 03:49 PM
