Quantcast TeamRush for 304 what do I need? Need Jeephammer advice - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > TeamRush for 304 what do I need? Need Jeephammer advice
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 07-20-2009, 12:11 PM   #1
DeadPhish
1977 CJ7
I have been reading everything about the team rush upgrade and it sounds like something that will work great for me. I am not sure exactly what I have and what I need can anyone help me out with this.
Here are some pictures of what i have right now
DeadPhish is offline   Reply With Quote
Old 07-20-2009, 01:51 PM   #2
DeadPhish
1977 CJ7
i still cant find anything that reflects the 304
Old 07-20-2009, 01:55 PM   #3
incynr8
1974 CJ5
here is the only thread I found and participated in regarding the AMC V8 upgrade using a CDI and a Motorcraft style distributor with big wires and the huge cap, it even list parts numbers and we discussed cost. I have yet to do it myself, but probably will next tune up.
http://www.earlycj5.com/forums/showthread.php?t=64494
incynr8 is offline   Reply With Quote
Old 07-20-2009, 02:05 PM   #4
kmm
I'll be watching this thread, as I am also thinking of doing "Team Rush". I have a mostly stock 1979 - 304 motor with the exception of Edelbrock intake and 4 barrel carb. I would like to do the first stage soon and would appreciate any part numbers needed and associated with the v-8. I don't know but if Jeephammer has ever thought of putting together some kits for the upgrades I would certainlly like to purchase one, also with installation details.
Thank you
kmm is offline   Reply With Quote
Old 07-20-2009, 03:28 PM   #5
Foulplay
1978 CJ7
I'm in the process of doing the "Team Rush" upgrade on my 304 right now. I purchased the MSD "Cap-Adapt" (part # 8414) from O'Reilly Auto Parts. It included the cap, adaptor and rotor. They had to order it but it was in the next day. I paid $56 for that including shipping. I also purchased new AC Delco plugs. The only issue I'm running into right now is finding plug wires that are the right length. The stock distributor cap has female fittings for the plug wires and the MSD has male fittings, so I'm having to find wires for another vehicle that uses a male distributor cap and close to equal length wires. I have a buddy at a Ford dealership working finding me some wires and the E-coil.
Project Money Pit:
1978 CJ-7 "Golden Eagle"
304 V8, 3spd manual
"Team Rush" upgrade
http://s125.photobucket.com/albums/p44/Foulplay_photo/Jeep/
Foulplay is offline   Reply With Quote
Old 07-20-2009, 03:44 PM   #6
DeadPhish
1977 CJ7
yea the part numbers and an explanation of what to do is something that I am looking for.
Old 07-20-2009, 03:48 PM   #7
scottymac62
SEAL Team VI
scottymac62's Avatar
1977 CJ5
I used the following parts to get my 304's ignition upgraded
Re-manufactured Duraspark dizzy from NAPA (1979 model)
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD-8414&N=700+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD-3119&N=700+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM-850602&N=700+400304+322383+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM-850500M&N=700+400304+115&autoview=sku
How to do it;;;;;;;;;;;;; http://www.iitp.com/PHP-Nuke/modules.php?name=News&file=article&sid=5
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, 575 Flex-A-Lite, FlowKooler, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
scottymac62 is offline   Reply With Quote
Old 07-20-2009, 03:52 PM   #8
scottymac62
SEAL Team VI
1977 CJ5
You will have to cut your own wires to get them to fit right. I used these wires by MSD and they are great wires. A little spency but worth it in my book. They work perfect with the MSD Cap-Adapt.
http://www.summitracing.com/parts/MSD-3119?autofilter=1&part=MSD-3119&N=700+115&autoview=sku
Old 07-20-2009, 03:53 PM   #9
CSP
phishmaster the distributor you have will not work with the upgrade parts. You have a Prestolite distributor and you need the Motorcraft/Duraspark distributor found on any AMC V8 from '78-91.
I find it hard to believe that you can't find any info though. I've seen JeepHammer, aka TeamRush, aka Junkyard Genius posting the same info ad nauseum for the V8 and I6 for a good ten years now on several forums. Many other people have also documented their upgrades and distributor swaps on webpages.
Have you googled it (Team Rush upgrade)?
CSP is online now   Reply With Quote
Old 07-20-2009, 03:58 PM   #10
DeadPhish
1977 CJ7
everything i find refers to the 6cyl i found one article where jeep hammer tallks about the v8's but not in detail and honestly I am not sure what I have so I need to get a good starting point and go from there.
Old 07-20-2009, 04:03 PM   #11
CSP
Where have you looked?
Honestly, the V8 info has been posted countless times.
I just told you what you have and that it won't work without changing the distributor.
This is as much spoon feeding as I'm willing to provide.
http://www.google.com/search?hl=en&q=team+rush+v8+upgrade
JeepHammer's own webpage:
http://www.junkyardgenius.com/ignition/jeep/jeep01.html
Old 07-20-2009, 04:06 PM   #12
scottymac62
SEAL Team VI
1977 CJ5
There is not that much difference between the I6 and V8 for this upgrade except for 2 extra cylinders on the V8. Replacing the dizzy uses the same TDC method for both. After your diizzy is in place, the rest is just plug and play for the most part. No rocket science involved.
Here's a nice pic from JeepHammer showing the V8 hookup.
Old 07-20-2009, 04:19 PM   #13
DeadPhish
1977 CJ7
thanks for all the help im not looking to be spoon fed i just honestly have no idea what parts to buy and replace. I just found out that the dizzy in my 77 had to be replaced. I didnt know that. I am going to try and get a parts list together and go to napa and order this stuff.
Old 07-20-2009, 04:36 PM   #14
Foulplay
1978 CJ7
Do I have to replace the ignition box to get the full effect or can I continue to run the stock Duraspark module?
Project Money Pit:
304 V8, 3spd manual
"Team Rush" upgrade
Old 07-20-2009, 04:40 PM   #15
CSP
You can run the stock module and still see a noticable difference. Another option is the GM HEI ignition module, which JeepHammer has also covered.
The use of the E-core coil is where you see the most bang for your buck.
Glock Forum
