01-11-2009, 10:59 PM
#16
Running On Empty...
Try here, I'm getting ready to cover it all again...
http://www.jeepforum.com/forum/showt...=1#post6340590
REMEMBER,
LINK: BASIC WIRING 101.
LINK: Dual Battery Diagrams & Explanations.
LINK: Winch, Welding, 'Lend Power' Project,
LINK: Water Proofing Ignition, Hubs, Ect.,
LINK: Small Cap 'HEI' V-8 Distributor.
LINK: Low Budget Fuel Injection Distributor,
LINK: AMC V-8 Front Cover Recondition,
LINK: Tuning An AMC V-8,
LINK: Ignition Swaps '77 Older Jeeps,
LINK: '78-'90 Jeep Ignition Upgrades,
01-21-2009, 07:56 PM
#17
i finally found the spare time to do the upgrade! first two words that comes to mind- "simply amazing" props to jeep hammer!
-lifes short drive topless...
01-21-2009, 10:56 PM
#18
Running On Empty...
Hey, even a blind pig finds an acorn once in a while!
Live to be as old as me, and you are BOUND to stumble into something good once or twice!
REMEMBER,
01-21-2009, 11:04 PM
#19
Hey Jeephammer, is there anything special about that tall rotor. When I get it should I just ask for a tall rotor?
01-21-2009, 11:14 PM
#20
Running On Empty...
No, you should ask for the rotor for the cap you are using...
If you use the tall I-6 cap, then use the tall I-6 rotor for the same year as the cap.
If you use the tall V-8 cap, then use the tall V-8 rotor for the same year as the cap...
REMEMBER,
01-21-2009, 11:24 PM
#21
Sorry I should have been clear. I am doing the rush upgrade and have the adapter and cap in place and was wondering if I had the right rotor. I am waiting for the MSD Coil wire and power tower to come in, so I didn't know if I had the right rotor. Thanks for the help.
01-18-2011, 07:42 AM
#22
something I have found is that if you get the cap and rotor from a ford bronco with the 300 cid I-6 and the bottom portion it will all fit on a cj distributor... and with that cap and rotor it will separate the spacing of the wires more so that there isn't any chance of a spark jumping inside the cap... It works great on mine...
01-18-2011, 08:20 AM
#23
Mall-crawlin' hot rodder
Yep yep!
Shawn
"I don't have an opinion, I have a dyno." -David Vizard
I was attacked by two clowns lastnight. I went for the juggler...
