Quantcast team rush upgrade...here goes nothing - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > team rush upgrade...here goes nothing
RUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp SeriesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 01-09-2009, 03:26 PM   #1
kyle_bob
1981 CJ7
ok i went to napa and got all the parts i think i need to do the team rush upgrade i got a cap, rotor,cap adaptor,ignition coil, some wires,and a coil connector...i was wondering about spark plugs i didnt get any yet because i was wondering what you guys thought. The website i am getting all the info on is http://www.jeepz.com/forum/engine/16904-tfi-ignition-upgrade.html they dont say anything about plugs on there, anything else anyone would recommend i get or some tips on doing this upgrade would be appreciated.
-lifes short drive topless...
kyle_bob is offline   Reply With Quote
Old 01-09-2009, 04:12 PM   #2
143hc
I'm using Champion truck plugs.
Now, 84 CJ7 Laredo , weber 38, 3.73's, Alloy 1pc., AuburnGears LS, hei/tfi, 2.5" BDS, Perf. Access. Years ago, 81 CJ7 304, 33's
143hc is offline   Reply With Quote
Old 01-09-2009, 04:18 PM   #3
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
X2 on Champion.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline   Reply With Quote
Old 01-09-2009, 04:24 PM   #4
jumbojeepman
1976 CJ7
I use Autolites. I mean, you are using a mostly Ford ignition, why not go all the way and use Ford spark plugs?
jumbojeepman is offline   Reply With Quote
Old 01-09-2009, 08:10 PM   #5
CJ Chet
Champion #4412!
Beer is the answer - it doesn't matter what the question is!
'86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift.
'04 TJ Sahara.
'00 TJ Sahara.
CJ Chet is offline   Reply With Quote
Old 01-09-2009, 08:43 PM   #6
cincyjeeprs
I have never seen any mention of using a different type plug than the stock number in any of those write-ups. Just open them up to 0.045 from 0.035. I use either the standard copper plus or the truck plug (both Champion).
cincyjeeprs is online now   Reply With Quote
Old 01-09-2009, 10:22 PM   #7
JeepHammer
Running On Empty...
1973 CJ5
Well, you might ask me, since I'm 'TeamRush' that 'Jeepz.com' gives credit to for the upgrade!
And you should use a PREMIUM spark plug for your year/type of engine.
If you have an '81 CJ with a (guessing) 258, then get an Autolite Premium plug for an '81 CJ with a 258.
Gap should be between 0.040" and 0.045" after you do the large cap and tall rotor upgrade.
If you have a V-8, you should upgrade the ignition coil to an E-core coil.
If you have a I-6, then the coil is an option, and not completely a necessity.
NOW!
Bear in mind that your 28 year old ignition module might not live up to the new parts and new demands...
Consider using a 'Stealth HEI' if it quits on you...
That's simply taking the 'Guts' out of your existing module, and substituting a GM HEI module for the Ford 'Guts'.
Costs about $25 and takes about 2 hours to do.
http://www.junkyardgenius.com/ignition/jeep/HEI01.html
In fact, I'm addressing some module questions over there right now as we are communicating... As 'TeamRush'...
JeepHammer is offline   Reply With Quote
Old 01-09-2009, 11:17 PM   #8
carnuck
1984 J-Series Truck
I use Autolites or NGK BKR6EKs if it pings.
carnuck is offline   Reply With Quote
Old 01-10-2009, 12:13 AM   #9
keith460
Jeep. There's Only One
keith460's Avatar
Here's what I bought and did.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums/showthread.php?t=434226
keith460 is offline   Reply With Quote
Old 01-10-2009, 05:34 AM   #10
JeepHammer
Running On Empty...
1973 CJ5
KEITH! That is the CLEANEST I-6 Engine I've ever seen!
I only have one qustion...
Shouldn't there be a 'Jeep' wrapped around it?
Old 01-10-2009, 07:33 AM   #11
keith460
keith460's Avatar
Well, that engine didn't always look like that!
I'm still working on wrapping that Jeep around that too.
1984 CJ-7 Renegade
Old 01-10-2009, 07:33 AM   #12
dalefan388
1979 CJ5
i got all of that when i do mine. (dont have a garage and its cold) but im keeping my stock coil for now and bought a adaptor from msd you put in your coil to have the tower thats matches your new wires. i think the part was #84039.
79 cj5/258ci/2.5" pro comp lift/31" tires/team rush/msd box/motorcraft carb
dalefan388 is offline   Reply With Quote
Old 01-11-2009, 05:21 AM   #13
Bubba Ray
dalefan, did that adapter work for you? Where did you buy it?
Bubba Ray is offline   Reply With Quote
Old 01-11-2009, 03:23 PM   #14
dalefan388
1979 CJ5
i ordered it though my work at advance auto. if you go there and ask for it make sure your talking to someone who knows what there doing. they have to get the # out of the msd book.
Old 01-11-2009, 04:13 PM   #15
lineguyj82
1978 CJ7
what exactly is the team rush upgrade?
I saw some the items mentioned in this thread. can some give me a whole run down , and some prices. looks like a great upgrade. Do u have to mess with the timing afterwards? never used a timing light always had a buddy that did that type of stuff. i have a 258 in my 78 cj7 with a 3spd. with howell tbi. any help would be appreciated.
lineguyj82 is offline   Reply With Quote
Glock Forum
