#1 | |
Team Rush upgrade
When doing the 'Team Rush' upgrade, will an Accel 'Super Coil' work in lieu of the Ford 'E' core coil ??
#2 |
Yes, I used an Accel and it worked great.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress) 1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress) |
#3 |
Running On Empty...
Some 'Super Coils' won't work with the Ford DuraSpark module, but if you have a 'Super Coil' now and it's working, you will be fine.
REMEMBER, 'Free' internet information is worth EXACTLY what you paid for it! LINK:Dual Battery Diagrams & Explanations. LINK:Winch, Welding, 'Lend Power' Project, LINK:Water Proofing Ignition, Hubs, Ect., LINK:BSERK's Winch Plate, LINK:AMC V-8 Front Cover Recondition, LINK:How An Ignition Works, LINK:Ignition Swaps '77 Older Jeeps, LINK:'78-'90 Jeep Ignition Upgrades, |
#4 | |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I wanted the hottest spark I could get, so was asking about running 12-14 volts straight to the coil. They said the coil puts out full with the resistor wire, but it would work with 12-14 volts without 'it' burning up.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#5 |
I've been adding to my list on the Team Rush upgrade:
E-Core Coil http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2D8227&N=700+ 115&autoview=sku Was recommended by Jeep Hammer, if buying new parts. |
#6 | ||
Running On Empty...
Anyway, if its working now, then it will work instead of the Ford style E-core coil. Just FYI, there really isn't much difference between the output of the Canister, E-core or Super Coil with line voltage... The E-core just saturates MUCH faster when the RPM reaches 2,000 or above, and since most guys don't operate an I-6 above 2,000 RPM, it's not really an issue! Quote:
Best quality and comparative price for the premium coils. If I'm doing this for myself or a local guy, I get a Ford E-core from the local 'U-Pull' salvage yard. You can get the coil, connector and mount all for about $5.
#7 |
Running On Empty...
double post.
#8 | |
Off Road Forever
I might go with the Team Rush cap and rotor setup next time. I just want to junk yard crawl for the adapter parts.
#9 | |
Running On Empty...
I'm thinking they only used that type in '81-'82, every thing else is 'Clip On' so make sure the adapter is SCREW DOWN when you find it! (All caps are 'Clip On' we are talking specifically about the 'Adapter' Base to distributor connection...) ------------------------ I HATE finding those carbon tracks on the rotor and inside of the cap! BUT, More Spark Voltage means more cross fire potential, no way around it! Wider cap just adds real-estate between the terminals, and between the rotor conductor and the grounds inside the distributor, so it's no big secret... Venting the I-6 cap helps. Anytime you can remove the ionized air you take away the path the spark energy uses to cross fire and ground fire. I'm pretty good with a drill and some MIG welder tips if the guy has an on board air compressor! (MIG welder tips make GREAT nozzles, threaded, perfectly fit vacuum/low pressure lines, and the precise size hole makes a good regulator/restriction so you don't blow the cap off!) Nothing like some compressed air in the distributor to chase off the ionization and keep water out when you are in the slop! Easy to do also, Parts, Cap, rotor, Cap Adapter, ![]() Plug wires ![]() Cap Adapter & Rotor Installed, ![]() Distributor cap and plug wires installed, ![]() The 'RED' thing in the top of the coil is a terminal adapter. On this particular conversion, the guy didn't want to use the E-core coil, and the new plug wires were set up for an E-core coil... If he would have told us sooner, we would have use Autolite Plug Wire Set p/n 96171 and got a Canister coil wire, But, this adapter is from MSD, This is what they look like in a set, ![]() And this is where you can get a single for the coil wire if you need one, http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2DASY11413&N= 700+115&autoview=sku
#10 |
Off Road Forever
Thanks for the part info, I like those adapters.
I won't be doing the swap until I need new wires. The OEM premium set I now have in are still going strong. As it sits, the engine red lines out at 4400 rpm, so I cant be having too many issues with it. If it ain't broke....
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
