Team Rush upgrade - JeepForum.com
post #1 of 16 Old 05-18-2013, 10:06 AM Thread Starter
LeePrather
1978 CJ5
Team Rush upgrade
I installed the 79 Ford F150 adapter and brass terminal cap/rotor. I'm finishing up the plug wires today (MSD 8.5 mm superconductor). I will be installing an MSD 6A CDI ingnition module on Monday. What's the optimum gap for my plugs after these upgrades?
LeePrather is offline
post #2 of 16 Old 05-18-2013, 10:14 AM
SCSEAJAYSEVEN
1978 CJ7
I gap my plugs at .045 (Motorcraft/Autolite 985). I have the same setup as you will have, I'm thinking I might close mine up to about .042 for a trial.
I set mine at .050 once, to try them out, that was too much. .045 is about as far as I would go. By the way, I'm not real sold on the MSD 6A. After that install, I saw very little, if any difference in the ignition. I had better performance with the Team Rush upgrade, Accel 8mm wires, and the Ford E-coil setup.
I just had to try it, $200.00 lesson to me...
Bert
SCSEAJAYSEVEN is offline
post #3 of 16 Old 05-18-2013, 10:18 AM
swatson454
1983 CJ7
I prefer no more than .040.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #4 of 16 Old 05-18-2013, 10:27 AM Thread Starter
LeePrather
1978 CJ5
But it does make sense to open them up more to gain more spark right?
post #5 of 16 Old 05-18-2013, 10:35 AM
swatson454
1983 CJ7
You've got all the spark you'll ever need with that box. It's just too bad that it's a bunch of short bursts instead of one, long zap. CDI is great for high-rpm stuff where coil saturation time becomes a problem but not so much for low rpm. Oh well...
There was a good thread on Speedtalk recently and all of the pros running CDIs were in the .035 to .038 range.
I ran .055 (briefly), .050, .045 and after a long conversation with Don at 4secondsflat.com, dropped to .039. The wise old racer was right.
Hope it helps.
Shawn
post #6 of 16 Old 05-18-2013, 10:45 AM
CSP
But Jeephammer said it's the best thing ever!
Are you saying that everything on the internet isn't true?
CSP is offline
post #7 of 16 Old 05-18-2013, 10:49 AM Thread Starter
LeePrather
1978 CJ5
I'm a French model...
post #8 of 16 Old 05-18-2013, 10:57 AM
swatson454
1983 CJ7
I'm just saying that's the experience I had when I was developing the ignition systems for John Force and Dale Earnhardt back in the '80s
Shawn
post #9 of 16 Old 05-18-2013, 11:44 AM
keith460
Jeep. There's Only One
keith460's Avatar
How is it that one can tell the difference between .040 and .045 gap? I would really like to know because I see no difference in color on my plugs from .035-.045 gap settings.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is online now
post #10 of 16 Old 05-18-2013, 12:06 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Uh, Bonjour!
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #11 of 16 Old 05-18-2013, 12:09 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Diminishing returns. Opening the gap make the coil have to build up more voltage to jump the gap, but there's a sweet spot, then it gets too big and costs you amperage. So even though the voltage is higher, the spark is weaker.
MSD's are great, but you have to remember their Multiple Spark feature only happens at 3k rpm and less. After that, it's one spark. Of course, 3k and under is where your Jeep motor is spending most of its life.
Jimmy V
post #12 of 16 Old 05-18-2013, 12:12 PM Thread Starter
LeePrather
1978 CJ5
So where would you say the sweet spot is?
post #13 of 16 Old 05-18-2013, 01:32 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Right in the .038-.043" range
Jimmy V
post #14 of 16 Old 05-18-2013, 02:25 PM
swatson454
1983 CJ7
I never even checked for color on that deal. The difference (albeit slight) was mostly with start ups and normal driving. It was enough for me to tell the difference and keep them there from here on out, though.
Shawn
post #15 of 16 Old 05-18-2013, 06:57 PM
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
Bert
I went the $129 route with the MSD Streetfire and have been very happy. Not giving up very much in the fire department and giving up a lot less in the wallet.
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
My jeep project "Rustful Dead"
HALOjmpr is offline
msd , team rush
