-   -   Team Rush upgrade (http://www.jeepforum.com/forum/f8/team-rush-upgrade-1525006/)
LeePrather 05-18-2013 10:06 AM
Team Rush upgrade
I installed the 79 Ford F150 adapter and brass terminal cap/rotor. I'm finishing up the plug wires today (MSD 8.5 mm superconductor). I will be installing an MSD 6A CDI ingnition module on Monday. What's the optimum gap for my plugs after these upgrades?
SCSEAJAYSEVEN 05-18-2013 10:14 AM
I gap my plugs at .045 (Motorcraft/Autolite 985). I have the same setup as you will have, I'm thinking I might close mine up to about .042 for a trial.
I set mine at .050 once, to try them out, that was too much. .045 is about as far as I would go. By the way, I'm not real sold on the MSD 6A. After that install, I saw very little, if any difference in the ignition. I had better performance with the Team Rush upgrade, Accel 8mm wires, and the Ford E-coil setup.
I just had to try it, $200.00 lesson to me...
Bert
swatson454 05-18-2013 10:18 AM
I prefer no more than .040.
Shawn
LeePrather 05-18-2013 10:27 AM
But it does make sense to open them up more to gain more spark right?
swatson454 05-18-2013 10:35 AM
You've got all the spark you'll ever need with that box. It's just too bad that it's a bunch of short bursts instead of one, long zap. CDI is great for high-rpm stuff where coil saturation time becomes a problem but not so much for low rpm. Oh well...
There was a good thread on Speedtalk recently and all of the pros running CDIs were in the .035 to .038 range.
I ran .055 (briefly), .050, .045 and after a long conversation with Don at 4secondsflat.com, dropped to .039. The wise old racer was right.
Hope it helps.
Shawn
CSP 05-18-2013 10:45 AM
But Jeephammer said it's the best thing ever!
Are you saying that everything on the internet isn't true? :D
LeePrather 05-18-2013 10:49 AM
I'm a French model...
swatson454 05-18-2013 10:57 AM
I'm just saying that's the experience I had when I was developing the ignition systems for John Force and Dale Earnhardt back in the '80s :rofl:
Shawn
keith460 05-18-2013 11:44 AM
How is it that one can tell the difference between .040 and .045 gap? I would really like to know because I see no difference in color on my plugs from .035-.045 gap settings.
Pacfanweb 05-18-2013 12:06 PM
Uh, Bonjour!
http://pbs.twimg.com/media/BAiklzACQAA-wME.jpg:large
Pacfanweb 05-18-2013 12:09 PM
Diminishing returns. Opening the gap make the coil have to build up more voltage to jump the gap, but there's a sweet spot, then it gets too big and costs you amperage. So even though the voltage is higher, the spark is weaker.
MSD's are great, but you have to remember their Multiple Spark feature only happens at 3k rpm and less. After that, it's one spark. Of course, 3k and under is where your Jeep motor is spending most of its life.
LeePrather 05-18-2013 12:12 PM
So where would you say the sweet spot is?
Pacfanweb 05-18-2013 01:32 PM
Right in the .038-.043" range
swatson454 05-18-2013 02:25 PM
I never even checked for color on that deal. The difference (albeit slight) was mostly with start ups and normal driving. It was enough for me to tell the difference and keep them there from here on out, though.
Shawn
HALOjmpr 05-18-2013 06:57 PM
Bert
I went the $129 route with the MSD Streetfire and have been very happy. Not giving up very much in the fire department and giving up a lot less in the wallet.
The time now is 11:59 AM.
