Tcase Movement ALOT - JeepForum.com
post #1 of 7 Old 01-21-2010, 04:15 PM Thread Starter
CopenhageCowboy
Tcase Movement ALOT
I installed my 4 inch lift and this included spacers for the tcase skidplate (crossmember) about 1.5'' and i was wheelin yesterday and got stuck, when i gave it gas to power out my tcase violently wobbled causeing my shifter to swing side to side pretty fast, ive never noticed this before but im not sure if its usual or not. i wish i could go into more detail but thats all i got. anyone know why this is or if its bad?
Cj's are like spoiled children, they use up every penny you earn and never seem appreciative. But no matter what happens you still love them. :]
CopenhageCowboy is offline
post #2 of 7 Old 01-21-2010, 04:25 PM
alex211
1995 XJ Cherokee
How are your motor mounts?
95 xj bone stock for now
alex211 is offline
post #3 of 7 Old 01-21-2010, 04:36 PM Thread Starter
CopenhageCowboy
when i dropped the tcase the motor tilted back a little bit. so im guessing they need replaced?
post #4 of 7 Old 01-21-2010, 04:38 PM
alex211
1995 XJ Cherokee
Well if the motor moves a lot when revved that's where the issue is, motor mounts. The T-case is connected to the motor through the tranny, so when the motor moves, so does the T-case.
alex211 is offline
post #5 of 7 Old 01-21-2010, 04:39 PM Thread Starter
CopenhageCowboy
ok ill have to check that out. thank you
post #6 of 7 Old 01-21-2010, 04:43 PM
Coiz
1979 CJ7
Don't forget to look at the trans mount and torque arm, if you have one.
Mike
Coiz is offline
post #7 of 7 Old 01-21-2010, 04:59 PM
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
Yeah when my tranny mount was shot my tcase was sitting terribly wrong and basically resting directly on the skid. This also caused my engine to sit WAY towards the driver's side, and the air cleaner (on the mc2100) to sit on top of the brake booster. (... and on and on it goes ...)
When I pulled the mount out it was basically mush old rotted rubber. Put the new mount in, the engine went back to where it was supposed to go, it left the space between the skid and the tcase.. and also my jeep stopped lurching right when I let off the gas.
.. all for a $10 tranny mount.
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
Excessive movement in throwout arm NelsonATC Jeep CJ Forum 6 11-20-2009 06:48 AM
new to jeep ALOT OF QUESTIONS C-olllo-J Jeep CJ Forum 4 06-15-2009 07:43 AM
shackle movement 82Renegade Jeep CJ Forum 2 01-11-2009 10:19 AM
New CJ7 owner with alot of questions SpencerC Jeep CJ Forum 30 10-15-2008 11:15 AM
I need alot of help, 258 or V8 DD dblock16 Jeep CJ Forum 18 10-30-2007 06:29 AM
