TBI problems - JeepForum.com
post #1 of 14 Old 08-23-2011, 02:46 PM Thread Starter
CJ7Rubicon
CJ7Rubicon's Avatar
TBI problems
I read thru the EFI sticky,could not find what I need.
I have a junkyard tbi upgrade,but with a affordable fi wiring kit and chip tuned to my upgrades.258,272? cam dual exhaust and bored 60 over..all clifford parts.
The jeep ran fine for 2 years,now when its warmed up it dies and the injectors flood the tbi after the motor stops.I have replaced the ecm and checked wiring.Any suggestions?
85 CJ7,Clifford equipped 258,TBI,RE4.5,35" Claws,Aussie lockers,8.8 rear.
Blue Jeep Club Member #134
CJ7Rubicon is offline
post #2 of 14 Old 08-23-2011, 02:50 PM
79jeepincj7
1979 CJ7
Id log some data.. and go here and repost your issue
http://www.binderplanet.com/forums/f...splay.php?f=75
Wheel - Wreck - Wrench - Repeat!
The VIN says its a 79 CJ
79jeepincj7 is offline
post #3 of 14 Old 08-23-2011, 02:59 PM
scrapman
It might be time to clean your injectors. I think I remember seeing a thread on here how to tear them apart and clean them.
If they are dumping fuel after your engine is off, it sounds like they are stuck open.
scrapman is offline
post #4 of 14 Old 08-23-2011, 03:16 PM
jcal73
jcal73's Avatar
2015 JK Wrangler
Do you have computer controlled spark?
Sounds like it's dying when you go into closed loop.
What distributor are you running?
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #5 of 14 Old 08-24-2011, 01:01 AM Thread Starter
CJ7Rubicon
CJ7Rubicon's Avatar
Jeff
No on the controlled spark,just fuel.Stock dist with the tfi upgrade using a msd6al.Whenever it dies the injectors continue to pump as if in crank mode,dumping more fuel than while running.
post #6 of 14 Old 08-24-2011, 11:31 AM
jcal73
jcal73's Avatar
2015 JK Wrangler
May be the MSD 6.
You could try to unplug the coolant temp sensor it may let it run in open loop and you could see if it dies when warmed up.
I don't know how to test the MSD, but I'm sure that someone on here can chime in with that.
Hope that helps
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #7 of 14 Old 09-08-2011, 11:27 PM Thread Starter
CJ7Rubicon
CJ7Rubicon's Avatar
Well its not the coolant temp sensor,I put a new one in.Same thing.Are the injectors sopposed to continue firing after the motor dies?The fuel pump continues to run also.
post #8 of 14 Old 09-09-2011, 10:21 AM
79jeepincj7
1979 CJ7
I'm telling you, go post this on the binder planet site. Bill is a Genius with this stuff
post #9 of 14 Old 09-09-2011, 10:43 AM
jcal73
jcal73's Avatar
2015 JK Wrangler
I didn't say it was the temp sensor.
I said unplug it to see if it would still run in open loop when warmed up.
If will run in open loop it may be something in the TBI.
If it will not it may be in the ignition or someting else.
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #10 of 14 Old 09-09-2011, 10:46 AM
jcal73
jcal73's Avatar
2015 JK Wrangler
X100 MR. BILL is the man on these things.
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #11 of 14 Old 09-09-2011, 10:57 AM Thread Starter
CJ7Rubicon
CJ7Rubicon's Avatar
Thanks,the cts was cheap to try,thats why i replaced it.
post #12 of 14 Old 09-18-2011, 02:13 PM
248107
Guest
1983 CJ7
Don't know if you got this fixed yet.I had the same problem on a Howell system a few years back.It turned out to be a shorted starter solenoid.
248107 is offline
post #13 of 14 Old 09-18-2011, 03:37 PM Thread Starter
CJ7Rubicon
CJ7Rubicon's Avatar
Did it still allow you to crank and run it for 10mins?I hope it turns out to be that simple!While at work I was reading up on it and that explains why it thinks its still running.I have yet to put together a cable to record data.
post #14 of 14 Old 09-18-2011, 07:28 PM
248107
Guest
1983 CJ7
Yep i could start it drive it. Just when i turned it off the fuel pump would run and pump fuel in till it run out the TB. It was just enough of a short at the solenoid it wouldn't turn the starter or make a noise. Finally after about a week it started ticking a little. I always had to disconnect the battery to shut the fuel off. It started after my son-in-law put a radio in it. Course he said he didn't cross any wires???? and maybe he didn't. Make sure you change oil in it,in case it got into the crankcase from overfilling into the cylinder. I went thru every procedure i could think of,even Howell was guessing after awhile.
248107 is offline
problems joshnix1992 Jeep CJ Forum 1 04-06-2011 06:16 PM
Problems with T90.... andrewferin Jeep CJ Forum 8 11-05-2010 01:00 AM
CJ7 MCU problems Help! dirthrider62 Jeep CJ Forum 4 03-05-2010 01:03 PM
New fan problems Jeepguy91 Jeep CJ Forum 4 06-04-2009 01:14 PM
258 problems devildoc Jeep CJ Forum 11 01-10-2007 09:59 PM
