TBI Fuel Pump Question - JeepForum.com
post #1 of 8 Old 09-08-2013, 02:04 PM Thread Starter
ericksin
1982 CJ7
I need a new 20-psi fuel pump for my Holley TBI system, my question is the flow rate.
One pump I'm looking at has a flow rate of 23gph, 20-psi for $50. the other is 50gph, 20-psi for $140. Does any one know what a TBI system needs as far as gph? and has any one replaced the TBI pump with an aftermarket pump?
My Holley Manual says it needs a minimum of 12-psi to operate properly but doesn't say anything about the gph.....
**** it, GAS IT!
ericksin is offline
post #2 of 8 Old 09-08-2013, 02:45 PM
jeepwhore
What are the outlet sizes on the two? Wouldn't a pump rated for twice the flow at the same psi have to have an outlet twice as large? That might help you figure out which one you need as last I checked a Jeep doesn't need a 3/4" fuel line.
**edit** Nevermind, been a while since I was last in school.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 8 Old 09-08-2013, 02:55 PM
Tyger78
Just a thought, Your TBI system has a fuel pressure regulator yes? If the system states that it requires a minimum of 12 psi, to me, that suggests that it also regulates it to 12 psi if it supplied with more.
So..... as long as you supply the TBI system with it's minimum (12 psi), the extra psi is going to be diverted and regulated back anyhow.
In theory of course, the only question would be "which one do you want, and would you have to adapt the inlet/outlet".
Of course, this is just me throwing some pennies around, as I'm no pro.
I've done lost my mind...... mind.... mind.... mind..... mind..... what a silly word.
Tyger78 is offline
post #4 of 8 Old 09-08-2013, 03:23 PM Thread Starter
ericksin
1982 CJ7
Yea... the manual says to set your regulator to 15-psi..... so I figured the cheaper pump should be ok, both pumps have a 3/8 in/outlet...... just checking to see if there something not seeing.
Thank
**** it, GAS IT!
ericksin is offline
post #5 of 8 Old 09-08-2013, 03:53 PM
Toine
Yes it will make a huge difference, especially at half till full trottle, you need that 50 gallon flow.
I have very good experience with the Airtex pump for TBI, rated @ 17psi, #E8094
cj7 305 V8 TH-700R4 D300 lomax, front & rear D44 4.88 with detroit lockers, 4'' skyjacker lift, Doetsch Baja Ryders & u-bolt flip kits
Toine is offline
post #6 of 8 Old 09-08-2013, 06:46 PM Thread Starter
ericksin
1982 CJ7
Well I was about to order the cheep pump till I seen your info.... I found the Airtex E8094 Electric Fuel Pump like you posted for $85.13 free shipping on Amazon.... what can you tell me about your experience with TBI's?
**** it, GAS IT!
ericksin is offline
post #7 of 8 Old 09-08-2013, 06:52 PM Thread Starter
ericksin
1982 CJ7
just found it on ebay for 71.99 free shipping
**** it, GAS IT!
ericksin is offline
post #8 of 8 Old 09-10-2013, 05:20 AM
Toine
My experience with the TBI is that it need really its pressure and flow for proper working injectors, this Airtex pump is a lot bigger and heavier than those cheap 14-15 psi pumps.
They can be loud when hot, but have a long life - mine run for 7 years now with 30.000 miles - still strong - I have one spare with me in case.
Go for it you would'n be dissapointed.
Toine is offline
