Tank is full, fuel gauge reads Half tank!?! - JeepForum.com
post #1 of 11 Old 09-24-2008, 11:53 AM Thread Starter
martyweir
1976 CJ7
I have stock dash cluster, and the fuel gauge is reading half full when tank is full (just filled her up for first time in several years).
I put in new temp gauge / fuel gauge about 3 years ago before storage. New Fuel sending unit at same time, and I'm pretty sure it worked then.
Any help on where to start here???
martyweir is offline
post #2 of 11 Old 09-24-2008, 12:11 PM
aero mech
aero mech's Avatar
1980 CJ7
Has it ever been acurate. I replaced mine and had to calibrate it by bending the float arm. You can also bend the stops. I ended up with 2 gallons left on empty and the had barely goes to full. Good luck. jc
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there"
aero mech is offline
post #3 of 11 Old 09-24-2008, 12:11 PM
whittlecj
1980 CJ7
http://www.jeepforum.com/forum/f8/fuel-guage-doesnt-work-607785/
I was going to recommend John Strenk's web pages but they seem to be down. If he needs a host I will provide if I can, they are too good to go missing from the net.
whittlecj is offline
post #4 of 11 Old 09-24-2008, 12:43 PM Thread Starter
martyweir
1976 CJ7
Thanks for the help aero. I may consider this, Will have tub off soon... WittleCJ, I read all of those, and didn't come across anything with guage working, but giving incorrect reading. Might be callibration issue / or voltage issue from gauge.
Anyone else ever have an issue w/ this?
post #5 of 11 Old 09-24-2008, 01:19 PM
Mike Romain
I would be checking the ohms from the sender on the pink wire.
The gauge 'can' be calibrated from behind. It has a range and top/bottom adjusting slot in the stock gauge.
Here is one page on the gauge diagnostics:
http://jeep.off-road.com/jeep/articl....jsp?id=261534
Mike
Mike Romain is offline
post #6 of 11 Old 09-24-2008, 01:48 PM
aero mech
aero mech's Avatar
1980 CJ7
Mike can you go into little more detail. I wasn't aware of this I am going to change my sending unit out soon beings it worked for two tanks of gas and now inop. You just can't find good replacement parts jc
post #7 of 11 Old 09-24-2008, 03:13 PM
Fjguercio
1978 CJ7
Dear Aero,
Take a look at the link in Mike Romains post... very good article and lists the resistance levels for the sensors so they can be checked out.
An example.
My CJ7 reads low on temp guage even when hot and going down the road. Using this write up link tested the cold reading and the Thermister is reading 47 ohm cold vs 73 ohms so close and will ck when hot and should be close to 9 ohms. If it is does not ohm out hot, I may need a new sensor.
Similar values were posted for the fuel tank and oil pressure systems.
Nice article, I printed it, Thanks Mike,
Fred
Fjguercio is offline
post #8 of 11 Old 09-25-2008, 03:47 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Maybe the float on the sending unit is filled with fuel and wont float anymore. Many guys go with a brass float now.
I'll see what's up with my web site.
John Strenk is offline
post #9 of 11 Old 09-25-2008, 03:56 AM
John Strenk
1976 CJ5
Ahh
Here we go...
http://home.roadrunner.com/~john.str...for_cj_gau.htm
http://home.roadrunner.com/~john.str...QuickFacts.htm
http://home.roadrunner.com/~john.str...eQuickTest.htm
http://home.roadrunner.com/~john.str...ageGauges1.htm
Still, maybe I need an alternate site to host them. Just in case. i was pretty jittery when I realized I might not have a backup to restore the pages.
whittlecj, you still offering some room?
post #10 of 11 Old 09-25-2008, 06:36 AM
whittlecj
1980 CJ7
Sure, PM sent.
post #11 of 11 Old 09-25-2008, 06:55 AM
aero mech
aero mech's Avatar
1980 CJ7
Originally Posted by Fjguercio View Post
Dear Aero,
An example.
Fred
Fred, Thanks for the tip. I understand about the omhs part. I tested mine before installing it and also filled the fuel tanks and checked it that way. I was actually refering to the adjustment on the gauge. I'll check the sight links posted up. Thanks again jc
New gas tank sending unit and now it reads half CJ7_Jim Jeep CJ Forum 6 11-14-2009 09:09 PM
Engine sputters at half a tank BrockGrimes Jeep CJ Forum 14 09-23-2009 06:23 PM
78 cj-5 fuel tank full of rust jimdubose Jeep CJ Forum 25 05-29-2009 10:08 AM
Gas Tank Leak ... But Only When Full ... HELP. cj newbie Jeep CJ Forum 12 02-08-2008 05:25 AM
tem gauge and size of gas tank thenubsterman Jeep CJ Forum 2 07-12-2005 08:30 AM
