Tales from the 258: Can you identify these hoses? - JeepForum.com
post #1 of 5 Old 07-04-2010, 02:53 PM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I'm starting work on cleaning up the plumbing after the Nutter, using this post where possible.
So far I've been able to pull the vaccum canister and that's about it. Can you identify the objects and lines in these two photos?
Photo #1: The red arrow points to a line that was capped off with a bolt:
Photo #2:
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #2 of 5 Old 07-04-2010, 04:29 PM
Mike Romain
I 'think' one is a non linear vacuum diverter for mixing the distributor vacuum up. It is an emissions part for sure that can go.
Number 2 is a recalled part that should be take out of the system. There should only be a T on that line picking up the charcoal canister only.
Mike
Mike Romain is offline
post #3 of 5 Old 07-04-2010, 05:12 PM
crzdmnky
1978 CJ5
I agree with mike, Took all this stuff off my heep as well. Actually I got rid of it all except the PCV, Vacuum advance, and Vacuum assisted choke...
crzdmnky is offline
post #4 of 5 Old 07-04-2010, 06:38 PM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
On the first part/photo (possible non-linear vac diverter): if I remove this, I'll be left with 2 unequal hoses. My choices are 1) join them together, or 2) cap them off. The large hose looks like a vent/vapor hose and the small one looks like a vaccum hose. Probably not a good idea to join them, eh?
I guess I need to figure out where they go before I can make the correct decision.
Ken
Ken4444 is offline
post #5 of 5 Old 07-04-2010, 06:49 PM
mcmud
1983 CJ8
That is a Decel valve.
Very worth while if you have plans to control vacuum advance with manifold signal. I have a hunch that there will be a gentleman on tomorrow who may want to speak to you about taking it of your hands, if you're so inclined and have no use for it.
This is a very useful site Jeep Adventures Under the Hood which will allow you to make a positive identification of each part under the hood.
mcmud is offline
I have no idea what to do with these hoses? RedHotChiliDog Jeep CJ Forum 7 06-01-2010 05:59 PM
Vac hoses kenny kustom Jeep CJ Forum 6 04-09-2008 03:10 PM
AMC 360 heater hoses StewartCJ7 Jeep CJ Forum 6 11-26-2007 11:23 AM
Help Identify Coolant Hoses Hybrid Jeep Jeep CJ Forum 4 11-17-2007 04:38 AM
Heater Hoses JERSEYJOE Jeep CJ Forum 5 08-19-2004 06:27 AM
