taking off body lift - JeepForum.com
post #1 of 10 Old 04-21-2013, 06:41 PM Thread Starter
neal90
1982 CJ7
Ill be taking 3 or 4 in body lift that i will be taking off. What are some thing i need to look out for. Its a 77 with a 304 and it auto thank
neal90 is offline
post #2 of 10 Old 04-21-2013, 10:45 PM
jodowii2
1980 CJ7
rusty bolts have fun
jodowii2 is offline
post #3 of 10 Old 04-22-2013, 05:23 AM Thread Starter
neal90
1982 CJ7
The body lift looks like it was done only a year or 2 ago so the bolts shouldn't be that bad. Just wondering about any linkages or any thing like that i should keep a look out for thanks
neal90 is offline
post #4 of 10 Old 04-22-2013, 05:37 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Loosen the bolts all the way around the Jeep, Then jack up one entire side, replace all of the mounts on that side, then move to the other side.
The whole task should only take you about 30-45 minutes.
Matt
Matt1981CJ7 is offline
post #5 of 10 Old 04-22-2013, 06:03 AM
John316
1976 CJ5
Neal,
What are you doing with your lift then? I will shoot you a PM....
Cheers,
John
John316 is offline
post #6 of 10 Old 04-22-2013, 06:25 AM
jeepwhore
Glad to hear of another person removing a huge body lift......hopefully it ends up in the garbage and isn't passed on to another forum member.....*hint hint*.
If the PO installed it correctly there should also be some brackets on the rad to remove. With an auto there isn't a whole lot more to consider I don't think. Just watch your brake lines off the master cylinder when you raise the tub to remove the blocks and also when you lower it to the new height.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #7 of 10 Old 04-22-2013, 07:28 AM
John316
1976 CJ5
I did a little more research on the body lift, and passed on the lift. Newbie mistake, and jumped the gun a bit. So JW, don't worry.
John316 is offline
post #8 of 10 Old 04-22-2013, 11:19 AM
jaketr1
1992 MJ Comanche
iv got to do this to mine soon, PO put some homemade crap on it and its about 3 inch, so might get the daystar 1inch with body mounts build in
jaketr1 is offline
post #9 of 10 Old 04-22-2013, 01:00 PM
ASteve
1972 CJ5
You may have to check ALL your body to frame linkages as the body lift removal will lessen your frame to body distance. (clutch linkage, radiator hoses, shifters etc...)
SC
ASteve is offline
post #10 of 10 Old 04-22-2013, 01:21 PM
Jeeprage
Jeeprage's Avatar
For all you looking to ditch the body lift, I have a brand new set of Poly stock size mounts I'd let go for cheap if wanted. I bought a full bushing set and ended up only using a few because I went with a fiberglass tub.
2015 JKU - 6m
Jeeprage is offline
