Takeing axle off jeep - JeepForum.com
post #1 of 11 Old 09-06-2017, 05:17 PM Thread Starter
Walts4x4
Do I take the springs off the frame and leave them attached to axle or do I leave springs on frame and take axle from springs?
Walts4x4 is offline
post #2 of 11 Old 09-06-2017, 06:14 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Support the axle with a transmission or rolling floor jack
Remove the u bolts (and all the other stuff that connects the housing to the frame)
Stabilize the axle
Drop the springs at the shackles
Lower the housing till it clears the underside of the rig and roll it out the back of the rig
bazinga
jeepdaddy2000 is online now
post #3 of 11 Old 09-06-2017, 07:23 PM
texasdave
texasdave's Avatar
1980 CJ7
Easier to move if you leave springs and tires on.
texasdave is offline
post #4 of 11 Old 09-06-2017, 08:27 PM
jeepdaddy2000
1971 CJ5
I think the plan is to take the housing to a shop to have the R&P/carrier replaced so it might be easier to simply roll the axle housing out on a jack sans all the extras.
bazinga
post #5 of 11 Old 09-18-2017, 02:10 PM
texasdave
texasdave's Avatar
1980 CJ7
^^ I agree if that what he going to do.
post #6 of 11 Old 09-18-2017, 03:28 PM
y2k-fxst
1964 CJ6
I'd cut the u-bolts off with a torch, then drop the shackles and roll the axle out from under the Jeep on the tires. A lot easier to move the axle on tires than to try to balance it on a jack, especially if your working by yourself. Take the tires off before trying to load it into the truck. Put the tires on to roll it under then jack it up to line up the springs,
I own a Harley and a JEEP, still some people can't figure out why I'm broke!
y2k-fxst is offline
post #7 of 11 Old 09-19-2017, 02:03 AM
80cj
80cj's Avatar
1980 CJ5
Lot easier to remove the tires when the axle is still on the Jeep, though.
80cj is offline
post #8 of 11 Old 09-19-2017, 05:34 AM
bob4703
1974 CJ5
Loosening lug nuts while axle is still on Jeep will make removing wheels easier when you remove axle and roll it to your truck.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #9 of 11 Old 09-19-2017, 05:53 AM
puppybreath
I always keep a couple of doughnut spares around for working with axles, they normally sit low enough that you don't have to lift the vehicle a mile and it's a lot easier to move around.
puppybreath is offline
post #10 of 11 Old 09-19-2017, 11:47 AM
Spieg8
1984 CJ8
^^ AGREE^^ My tires are big and the ceiling in my garage is low enough that my roll bar hits the ceiling before there is enough clearance to roll the axle out.
I don't have a set of small tires so I always remove the tires and set the axle on a dolly to get it from under the Jeep.
When I was younger, I thought I was Don Quixote... turns out I'm just another donkey-hootie.
Spieg8 is offline
post #11 of 11 Old 09-19-2017, 01:31 PM
y2k-fxst
1964 CJ6
Another idea to lower the axle to get it out from under is to cut circles out of 3/4" plywood just large enough to allow the pumpkin to clear the ground. Then drill holes for the center register and studs. Hold the wheels on use a couple of lug nuts turned backwards.
y2k-fxst is offline
