Tail light/brake light confusion..... - JeepForum.com
post #1 of 4 Old 08-13-2009, 08:55 PM Thread Starter
Skinnyfeet
1979 CJ7
Not that its that hard to do, but my brake lights/tail lights have me totally confused. A couple of days ago all the lights worked fine, then both tail lights quit working (bulbs are good). Today I discovered that one of the brake lights quit as well....sort of. It wasn't working so we turned on the blinker to see if it worked (it did), then stepped on the brake again and this time it worked fine.
Any ideas? If its a short, how exactly do you find it to fix it?
Skinnyfeet is offline
post #2 of 4 Old 08-13-2009, 09:16 PM
my-jeep-earl
1971 CJ5
Check all your grounds first, it usually ends up as that.
my-jeep-earl is offline
post #3 of 4 Old 08-14-2009, 05:25 AM
ACAD_Cowboy
1980 CJ7
Also check your brake lamp switch. My switch has a habit of walking backwards so the brake lamps are always on. When it is not doing that it likes to wiggle the connector free so they are then never on. It's a battle that one day I will win.
ACAD_Cowboy is offline
post #4 of 4 Old 08-14-2009, 09:13 AM
thewolff
Had the same problem on my 86 and on a friends 81. Jiggle the turn signal lever. Contacts needed cleaning. Check the wiring diagram. Crazy!
thewolff is offline
Short above tail light Aduffy32 Jeep CJ Forum 0 01-06-2010 12:01 PM
E brake light and speedo light all of a sudden!? ryanmanuel Jeep CJ Forum 2 11-23-2009 06:29 PM
TAIL/BRAKE light HELP!!!! (stupid noob question) kufd Jeep CJ Forum 3 08-14-2009 09:16 AM
tail light issue solitudetree Jeep CJ Forum 8 07-05-2007 01:32 PM
CJ 7 Tail light? krs-med Jeep CJ Forum 4 07-07-2006 08:36 PM
