Tack problems - JeepForum.com
post #1 of 8 Old 10-09-2002, 10:55 AM Thread Starter
dallen
Tack problems
Hi all. Is there any reason the stock tack in a 86 CJ7 should not work after installing a MorPar fuel injection system on the stock 4.2 engine. Thanks for your help.
dallen is offline
post #2 of 8 Old 10-09-2002, 11:17 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I am not sure I understand your question ..
Tack? Tank? Gastank maybe?
Fuel-injection system for the 4.2l (258ci) is a fairly simple (relative term) install .. all the problems were worked out to do the kit .. which one are you looking at, do you have it, is your Jeep in pieces right now as you are doing it?
More info .. please ..
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 8 Old 10-09-2002, 11:33 AM
Bob K
Bob K's Avatar
Tachometer?
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #4 of 8 Old 10-09-2002, 07:33 PM
werewolf7111
there shouldnt be-maybe a wire is knocked loose
joeMSME, PE.
werewolf7111 is offline
post #5 of 8 Old 10-09-2002, 08:26 PM
CSP
The stock CJ tach is not like any other tach. It does not simply read the ignition pulses like an aftermarket tach. It is wired in series and is an actual part of the ignition system. When you install the Mopar kit you eliminate the stock ignition altogether. The tach is part of what you eliminate. I know of a group of people were trying very hard to get a stock tach worked into the Mopar ignition, but I don't know if they were successful and never saw any more info on the web about it. Hesco (maker of Mopar kit) recommends you go to an AutoMeter tach and it must be switched to 4 cylinder to work with the Mopar MPI.
CSP is offline
post #6 of 8 Old 10-10-2002, 02:03 AM
Jeep Daddy
Jeep Daddy's Avatar
Very Interesting!
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #7 of 8 Old 10-10-2002, 12:49 PM
jeep1
1984 CJ8
Use the 4 cyl. CJ tach or the aftermarket lookalike. I have the MPI on a 258 and used the 4 cyl. cj tach.
jeep1 is offline
post #8 of 8 Old 10-10-2002, 05:12 PM Thread Starter
dallen
Thanks to all for your help.
dallen is offline
CJ5 Factory tack to MSD6A Magical_Merlin Jeep CJ Forum 2 02-10-2010 08:23 PM
Still having problems... ToxicGreenJeep Jeep CJ Forum 9 02-11-2007 12:41 PM
cj7 body repair-rivet/tack weld spot fix CJ7 Vette Jeep CJ Forum 9 05-28-2006 02:22 PM
73' cj problems syeldell Jeep CJ Forum 2 03-15-2004 12:33 PM
CJ -360 problems smokinstang70 Jeep CJ Forum 3 12-22-2003 02:16 PM
