-   -   Tack problems (http://www.jeepforum.com/forum/f8/tack-problems-20409/)
dallen 10-09-2002 10:55 AM
Tack problems
Hi all. Is there any reason the stock tack in a 86 CJ7 should not work after installing a MorPar fuel injection system on the stock 4.2 engine. Thanks for your help.
NaeKid 10-09-2002 11:17 AM
I am not sure I understand your question ..
Tack? Tank? Gastank maybe?
Fuel-injection system for the 4.2l (258ci) is a fairly simple (relative term) install .. all the problems were worked out to do the kit .. which one are you looking at, do you have it, is your Jeep in pieces right now as you are doing it?
More info .. please ..
Bob K 10-09-2002 11:33 AM
Tachometer?
werewolf7111 10-09-2002 07:33 PM
there shouldnt be-maybe a wire is knocked loose
joeMSME, PE.
CSP 10-09-2002 08:26 PM
The stock CJ tach is not like any other tach. It does not simply read the ignition pulses like an aftermarket tach. It is wired in series and is an actual part of the ignition system. When you install the Mopar kit you eliminate the stock ignition altogether. The tach is part of what you eliminate. I know of a group of people were trying very hard to get a stock tach worked into the Mopar ignition, but I don't know if they were successful and never saw any more info on the web about it. Hesco (maker of Mopar kit) recommends you go to an AutoMeter tach and it must be switched to 4 cylinder to work with the Mopar MPI.
Jeep Daddy 10-10-2002 02:03 AM
Very Interesting!:confused:
jeep1 10-10-2002 12:49 PM
Use the 4 cyl. CJ tach or the aftermarket lookalike. I have the MPI on a 258 and used the 4 cyl. cj tach.
dallen 10-10-2002 05:12 PM
Thanks to all for your help.
The time now is 08:32 PM.
