Tachometers - JeepForum.com
post #1 of 14 Old 07-22-2013, 07:33 AM Thread Starter
HeathFinnie
1976 CJ5
Tachometers
Did different engines use different tachs? I ask because I see some on eBay and some list the engine and others don't. Just curious.
Thanks!
HeathFinnie is offline
post #2 of 14 Old 07-22-2013, 07:43 AM
walkerhoundvm
1981 CJ8
Yes, all the originals were specific to the engine. The newer aftermarket Chinese junk tachs have a switch so you can change between engines.
walkerhoundvm is offline
post #3 of 14 Old 07-22-2013, 07:45 AM Thread Starter
HeathFinnie
1976 CJ5
Great- thanks!
If you find an OEM does it say which engine it works with?
post #4 of 14 Old 07-22-2013, 08:35 AM
walkerhoundvm
1981 CJ8
I think there is a printed number - 4, 6, or 8cyl on the back?
You can see in this one I pulled from eBay that there's a "6" printed:
post #5 of 14 Old 07-22-2013, 09:38 AM
John Strenk
John Strenk's Avatar
1976 CJ5
The 4 cylinder was a different design. It hooked up to the (-) post of the coil...
the 6 and 8 was an inline or series tach.
After market stuff was 4-6-8 selectable.
John Strenk is offline
post #6 of 14 Old 07-22-2013, 09:50 AM Thread Starter
HeathFinnie
1976 CJ5
Thanks. I want an OEM one so just wanted to know what to look for. I also have an HEI so no longer have a coil. (V8 304)
Thanks!
post #7 of 14 Old 07-22-2013, 09:59 AM
John Strenk
1976 CJ5
You still have a coil but it's under the cap..
a Stock Tach will work if it's inline with the power to the HEI distributor.
An aftermarket tach is needed to hook up to the TACH terminal on an HEI.
post #8 of 14 Old 07-22-2013, 10:08 AM
lsukevinc
1979 CJ5
what tach will work with a MSD box?
lsukevinc is offline
post #9 of 14 Old 07-22-2013, 11:06 AM Thread Starter
HeathFinnie
1976 CJ5
Aftermarket like a crown OEM styled? My HEI does have a tach terminal that is currently connected to a huge sunpro tach mounted under the dash. I want to remove that and clean up my dash with an in-dash tach and I'm trying to get all the gauges back to stock style.
post #10 of 14 Old 07-23-2013, 04:44 AM
John Strenk
1976 CJ5
I'd have to see it, if it has wires that looks like it goes to a set of earplugs off you iPhone then it will plug into the Tach plug. If the wires are big gauge like you can jump your battery with it, then it will hook up like original tach.
post #11 of 14 Old 07-23-2013, 10:02 AM
SLO_Ken
Is this true of any ignition system? Can I make the stock tach work with a later model 4.0 distributor/ignition?
I'm thinking if I splice the tach in K7 between S115 and the Cam Position Sensor? Or should it go inline with the coil (A142 after S109)? Or will this not work at all?
SLO_Ken is offline
post #12 of 14 Old 07-23-2013, 10:13 AM
John Strenk
1976 CJ5
The crank shaft position sensor run off a 5 volt supply. Might not be enough juice there for the tach.
The last would probably work better, Anywhere between the fuse and the (+) on the ignition coil
but the designation "Ignition coil #1" has me a little worried.
is there more than 1 coil?
post #13 of 14 Old 07-23-2013, 10:33 AM
SLO_Ken
No, only one coil on my '98 4.0. Jeep switched to coil-on-plug sometime in the early 2000's.
SLO_Ken is offline
post #14 of 14 Old 09-13-2013, 08:34 PM
SLO_Ken
Yup, this works! Although, I did have to tap in AFTER S109... otherwise, the fuel injectors and computer were also drawing through the tach, and it would bounce all over the place.
Thanks for helping me figure this out!
SLO_Ken is offline
