Tachometer Question - JeepForum.com
post #1 of 2 Old 08-29-2002, 08:41 AM Thread Starter
kev1
Question Tachometer Question
I am working on my 1980 CJ7 re-build. I am yanking the GM-151 and puting in a 1985 258 which has the HEI Mod. Does anyone know if I can use the tach. that was connected to the GM-151? If so where and which wire connects to the 258?
Thanks,
Kevin
1980 CJ7 Rebuild:
Frame painted with a Rough Country 2.5" lift and shocks installed.
Alot of money spent on parts that are all over including a new 258.
kev1 is offline
post #2 of 2 Old 08-29-2002, 06:04 PM
johnnyamc
I do not know if the 151 Tach itself will work but, hooking a tach up to an hei distributor is easy. It has two tabs underneath the bottom of the distributor. One hooks it to the car and the other hooks up the tach. This has been my experience on 350's anyway. Hope this helps
1978 Jeep CJ-7 T-400 Q-Trac New 304 edelbrock intake and 4 barrel carb, comp cam, .060 over, dogleg heads and it DOES have some power.Forget swapping in a 350 chevy. Always AMC.
johnnyamc is offline
Tachometer Question akdanny Jeep CJ Forum 4 05-12-2009 01:09 PM
original Tachometer question BioTex Jeep CJ Forum 4 10-28-2008 07:51 PM
Tachometer question. cj5fourbyfour Jeep CJ Forum 4 03-13-2008 05:08 AM
Tachometer? Aphelion79 Jeep CJ Forum 3 10-08-2003 08:11 AM
Tachometer question - 73 CJ5 304 v8 qualityhardware Jeep CJ Forum 1 06-22-2003 11:37 PM
