tach wiring - JeepForum.com
post #1 of 2 Old 02-13-2002, 08:43 PM Thread Starter
93vert
Post tach wiring
Can anyone tell me why I can't hook up an aftermarket tach to the tach plug on a factory '86 harness? The tach in question is a "factory replacement" tach from 4wd hardware, but same as all. In the instructions it says not to wire it to the factory plug. And I tried it and it doesn't work... Does the factory tach use some crazy wiring? Thanks
93vert is offline
post #2 of 2 Old 02-19-2002, 10:28 PM
CR SETH
Post
The factory tach uses the jeeps ingnision(spelling?) to get a signal. The factory replacement tack needs to be run to the tach side of the coil. Then to power and ground.
CR SETH is offline
Crown tach wiring on HEI Gemelos Jeep CJ Forum 8 01-26-2010 12:43 AM
AMC 360 Tach Wiring CJ Runner Jeep CJ Forum 4 03-21-2009 08:04 PM
Tach Wiring boutdoorhunter Jeep CJ Forum 3 02-09-2008 07:43 AM
Tach wiring help adam85cj7 Jeep CJ Forum 13 02-09-2007 09:17 PM
wiring a tach durdenclub Jeep CJ Forum 5 08-11-2004 05:32 AM
