Tach swap help - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Tach swap help
Premium LED Lighting by VISION X, Proudly sold at ROCKRIDGFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectCess Recovery Gear Snatch Tow Strap OffRoad @ ROCKRIDGE4WD
Unread 08-19-2014, 04:38 PM   #1
colledrolled
Tach swap help
I'm trying to replace the stock "inline" Tach with a Crown.
I dont know allot about this stuff so keep that in mind.
The old tach is "inline" on the wire that runs from the ignition to the coil. When I replace that tach with the new one, I connect the ignition side of the wire to the tach and the coil side is not connected to anything.
No wonder I have no power at the coil. What do I connect it to?
colledrolled is offline   Reply With Quote
Unread 08-19-2014, 07:04 PM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
You connect the two harness plugs together to continue the "series" connection and find a different power source for your aftermarket tach.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
