tach hookup - JeepForum.com
post #1 of 6 Old 12-12-2002, 04:15 PM Thread Starter
KG4PAM
tach hookup
could someone give me some pointers on tach hookup? i just got one and the instructions are a little vague. there are four wires on it, a green for tach signal, a black for ground, a red for ignition 'on' power, and a white for lights. the one i have a question about is the green. according to the instructions, i am to hook it up to the coil? if so, which side (pos or neg)? i have done the TFI upgrade, is hookup still the same? thanks for your help in advance! jairus
'81 CJ-7 Got it when I was 16!
'06 Hummer H3, boulder gray, Adventure Package(electric rear locker and 70:1 crawl ratio BONE STOCK)
'71 Kaiser-Jeep M35A2 Deuce and a Half cargo truck, with winch. <for sale>
KG4PAM is offline
post #2 of 6 Old 12-12-2002, 09:37 PM
SamFromCO
SamFromCO's Avatar
It hooks to your coil on the TFI setup but I can't remember which side and it's cold and dark outside. I'm thinking the negative side but since I have a 50-50 chance of being wrong, I probably am. I think that I hooked mine up to the wrong side first and it didn't work so using my tremendous power of deduction I hooked it up to the other side and it did.
SamFromCO is offline
post #3 of 6 Old 12-12-2002, 10:58 PM
Jeep Daddy
Jeep Daddy's Avatar
Yes, hook up is the same. I can't remember either but I think it is the negative side. I'd do the same as mentioned. Try it, if it doesn't work, change it. Also, you may need to configure your tach for 4 cyl if I remember correctly. Yes, I know, that sounds weird. Trust me, I read it on this board today. If you have the Mopar TFI, your tach needs to be set for 4 cyl. Do a search on Tach. You can read for yourself. HTH
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #4 of 6 Old 12-13-2002, 06:49 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Cool
It usually hooks up on the distributor side of the coil.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #5 of 6 Old 12-13-2002, 09:55 AM Thread Starter
KG4PAM
thanks! i searched 'tach hookup' on google and found how to as well. it looks like the negative side! thanks for your help!
btw, i may have got my acronyms mixed up, but the TFI i was talking about is the ford Thick Film Integrated distributor cap and coil upgrade, not fuel injection. jairus
KG4PAM is offline
post #6 of 6 Old 12-14-2002, 09:02 PM Thread Starter
KG4PAM
tach works great! thanks for yall's suggestions! jairus
KG4PAM is offline
Gauge hookup kstopp Jeep CJ Forum 7 02-17-2008 09:36 AM
fuel tank hookup compumasta Jeep CJ Forum 7 06-16-2007 08:52 PM
Fuel gauge hookup AMSting Jeep CJ Forum 1 06-13-2007 11:44 AM
Winch Hookup jamesa Jeep CJ Forum 9 11-10-2006 04:06 AM
distributor hookup KG4PAM Jeep CJ Forum 2 01-24-2003 12:31 AM
