T14/Dana 20 vs T176/Dana 300 - JeepForum.com
post #1 of 6 Old 12-27-2007, 10:23 PM Thread Starter
kbazurpe
kbazurpe's Avatar
1973 CJ5
I'm working on building a CJ5 and have two tranny/transfer case combination possibilities. I've got about $200 in new parts for the T14/D20, but am thinking about going with the T176/D300. How much of an advantage do you think going with the T176/D300 would be? It would allow for lower gearing and should result in better fuel economy since it is a 4sp instead of a 3sp.
Transmission 1st 2nd 3rd 4th Rev
T-14 3.10 2.61 1.00 3.10
T-176 3.52 2.27 1.46 1.00 3.52
Dana 20 2.03:1
Dana 300 2.62:1
tell me what you think
kbazurpe is offline
post #2 of 6 Old 12-27-2007, 10:32 PM
jp360cj
1977 CJ7
I'd go with the 176/300 for the better gearing. It's not only lower, but 2nd 3rd and 4th are a lot closer than 2nd and 3rd on the 14. I've got a t150 and my biggest gripe is the power loss from 2nd to 3rd. It'd be really nice to have that extra gear to keep it in the power band. It's not as bad since i ditched the 258 for a 360, but with that 6 cyl i had to wind out 2nd to have any power in 3rd
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #3 of 6 Old 12-28-2007, 12:45 AM
80cj
80cj's Avatar
1980 CJ5
Both T-14 and T-176 trannies have 1:1 high gear ratios so there should be no difference in gas mileage. Also, T-176 is stronger than the T-14.
80cj is online now
post #4 of 6 Old 12-28-2007, 05:22 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
T 14's in my experience, won't hold up well to any power or abuse. The 176 is a much stronger trans. The bell bolt patterns will be different as well, so you may need to swap/adapt to get one or the other to fit. Fuel economy will be about the same either way.
jeepdaddy2000 is offline
post #5 of 6 Old 12-28-2007, 05:29 AM
HackFabrication
HackFabrication's Avatar
1976 CJ5
T176/300 combo. Hands down. Just a better pairing of gears. Plus the 300 has more aftermarket 'options' than the 20 does.
"In the end...It's all Hack."
HackFabrication is online now
post #6 of 6 Old 12-28-2007, 08:47 AM
80cj
80cj's Avatar
1980 CJ5
Your T-176 could very well be a T-177 which means that it will have a 3.82 first gear. Check the numbers on the tag on the passenger side front of the case.
5359389 = T-177
5359390 = T-176
80cj is online now
T176 to dana 300/T18-1B lucdog Jeep CJ Forum 27 01-20-2010 04:37 PM
Dana 300 and T176 in CJ5 bluesman423 Jeep CJ Forum 6 06-22-2009 11:27 AM
Switch from T176 and Dana 300 to T150 and Dana 20?? Need Advice CJ5Freak Jeep CJ Forum 11 07-26-2008 06:56 AM
t176----->dana 300 lepurcon Jeep CJ Forum 8 01-28-2008 05:13 PM
T176 to Dana 300 Bard Jeep CJ Forum 0 01-14-2007 04:06 PM
