T-999 Transmissions on 80-86 CJ7's - JeepForum.com
post #1 of 6 Old 11-01-2006, 01:09 PM Thread Starter
jeepdude1107
Were the T-999 tranny's made different in the later models. I am currently doing a swap from an 82' to and 86' T-999. we noticed that there is a difference in the input shaft between the two of them, which would not allow the torque converter to fit on the newer model tranny. Does anyone have any ideas to why this is so or should the torque converter fit on both trannys?
1982 CJ7
2" Rough Country Suspension Lift
31" x 10.5" Tires
15" American Racing Alloy Wheels
jeepdude1107 is offline
post #2 of 6 Old 11-01-2006, 01:25 PM
BLS33
Chief of the brain police
BLS33's Avatar
whats the difference on the shafts
BLS33 is offline
post #3 of 6 Old 11-01-2006, 02:31 PM Thread Starter
jeepdude1107
The difference on the shafts is very small. the input shaft tip on the 82' tranny is smooth (meaning the splines do not go all the way to the end) and there are 27 splines on the rest of the shaft. ON the 86' tranny input shaft there are 26 splines and they go all the way to the end of the shaft.....if that makes sense.
1982 CJ7
31" x 10.5" Tires
post #4 of 6 Old 11-01-2006, 03:10 PM
BLS33
BLS33's Avatar
Yep it makes perfect sense, one uses a lock up converter, the other a non lock up. On a tranny that uses a lock up converter the splines stop short, while a non lock up go all the way to the end
BLS33 is offline
post #5 of 6 Old 11-01-2006, 05:24 PM Thread Starter
jeepdude1107
OK thanks thats what I was thinking but I was not sure what consituted a lock up converter or not. Will it make a difference whether or not I put a non lock converter in my cj that originally had a lock up converter? If so, what will be the difference? Will it work?
1982 CJ7
31" x 10.5" Tires
post #6 of 6 Old 11-01-2006, 09:23 PM
Aphelion79
Aphelion79's Avatar
Maybe ask if it is possible to swap shafts?
1982 CJ7
Iron Duke "Hurricane" 151 CID 2.5L 4-Cyl
T177 Tranny | Dana 300 T-Case
Dana 30 Front | AMC 20 Rear
Aphelion79 is offline
Did you know....CJ7's... mtndew1 Jeep CJ Forum 12 07-31-2009 08:57 AM
How many 1986 CJ7's LT1CJ7 Jeep CJ Forum 3 07-26-2007 10:43 AM
4 cyl. CJ7's 79cherokee Jeep CJ Forum 8 06-26-2007 02:55 PM
Did 84 CJ7's have a I6 engine? 84 CJ7 Jeep CJ Forum 13 07-12-2006 08:37 AM
CJ7's ONENICE92YJ Jeep CJ Forum 14 04-30-2003 07:13 PM
