t-90 lever mystery - JeepForum.com
post #1 of 4 Old 01-21-2010, 09:04 PM Thread Starter
barlow
1966 CJ5
t-90 lever mystery
Hello all, On my 66' cj there is a lever which extends out from the tranny, which moves back and forth. The PO mentioned this was used as some type of ebrake?? I don't the purpose of this lever? Thanks for any thoughts.
barlow is offline
post #2 of 4 Old 01-21-2010, 09:27 PM
80cj
80cj's Avatar
1980 CJ5
If it's not the tranny shifter and it's not the transfer case shifter, then it's very likely and overdrive shifter. Look underneath and see if there's and extra aluminum housing back of the transfer case. Better yet, send a picture.
80cj is online now
post #3 of 4 Old 01-21-2010, 10:19 PM
Fourtrail
1974 CJ6
Yes it would be a parking brake. There is a drum mounted to the rear of the dana 18 transfer case and a set of drum brake shoes inside. Should be a cable that runs from the lever to a locking pull handle under the dash.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #4 of 4 Old 01-22-2010, 12:15 AM
80cj
80cj's Avatar
1980 CJ5
As I remember, those model CJ's had a handle that you pulled on under the dash unless somebody changed it to a lever over by the transmission shifter (as I understand barlow's description).
80cj is online now
T-176 Shift lever removal holtmeier Jeep CJ Forum 9 10-17-2011 07:17 PM
T-4 vs T-176 shift lever BioTex Jeep CJ Forum 17 10-15-2008 09:52 AM
cj lever door handles newjeepowner Jeep CJ Forum 4 06-03-2008 06:18 AM
1980 CJ5 Key release lever PPelt3 Jeep CJ Forum 0 05-04-2008 01:14 PM
77 CJ7 Low Range Shift Lever 77CJ7-AZ Jeep CJ Forum 1 02-12-2007 04:02 PM
