T-5 to TF999 mounting issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > T-5 to TF999 mounting issues
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 06-09-2013, 10:53 AM   #1
supersport126
well got engine installed yesterday and I must have wrong trans mount or torque plate cause the trans wont even drop down enough to hit the skid plate before engine starts to hit fire wall as it pivots. I'm using the same torque plate from T-5 and new mounts but its not even close. Anyone have a picture of their auto trans mount?
supersport126 is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 11:52 AM   #2
only in a jeep cj
If I had to guess, your missing the "w" bracket used in auto mount applications
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 11:56 AM   #3
supersport126
Ahh, yep that makes sense. That's the missing link right there. Thank you!
Unread 06-10-2013, 09:15 AM   #4
CJ Chet
When I did mine I also had to redrill my pan.
Beer is the answer - it doesn't matter what the question is!
'86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift.
'04 AEV RUBICON.
'00 TJ Sahara.
CJ Chet is offline   Reply With Quote Quick reply to this message
Unread 06-10-2013, 10:51 PM   #5
supersport126
fixed that problem, went and got some 2" square stock and got the trans mounted to the skid plate. Its probably a little taller then the stock "W" bracket but I can always drop the skid plate a bit. I offset my drill holes to allow the trans mount to line up perfect with the lowest or most rearward mounting holes.
Unread 06-11-2013, 11:22 AM   #6
BigWheelBob
That should work great!
BigWheelBob is offline   Reply With Quote Quick reply to this message
