T-18 tranny removal - JeepForum.com
post #1 of 5 Old 10-20-2011, 07:36 PM Thread Starter
jeeptree2112
T-18 tranny removal
cant figure out how to get the shifter off the T-18. Took the floor cover off and there seems to be a metal cover over the shifter yoke that is seized on over it. Any suggestions?? I'm replacing my clutch and this is my first go at dropping transfer cases, drive shafts, tranny's etc. Step by step. Right now I want the shifters out. Thanks for the input
jeeptree2112 is offline
post #2 of 5 Old 10-20-2011, 07:48 PM
44231GUY
what you need to do is drop the trans and let the shifter come down the hole with it, when it is on the ground you can rotate it to get the trans out from unerneath, it helped me to drain the fluid out first.
44231GUY is offline
post #3 of 5 Old 10-20-2011, 08:09 PM
har99
1979 CJ7
There is a metal domed cap that slips down the shift lever and threads onto the shift tower. The domed cap may have a flange area around the bottom. Twist it off like a nut. Once you have that off the shifter will pull straight up-n-out. Be careful, there is one loose pin on either side of the shifter pivot ball. With the shift lever in place and the threaded on cap in place they cannot go anywhere, but once you remove the domed threaded cap they can fall out. They usually just sit there but it's good to watch out for them. Dont let them fall inside! Best to put in neutral to re-install also. see this link for pic: http://www.fordification.com/tech/im...fter_T1819.jpg
har99 is offline
post #4 of 5 Old 10-20-2011, 08:38 PM
FLynes
De Oppresso Liber
FLynes's Avatar
1976 CJ5
^ This.
I just did the same thing to my T-150, which is held on like your T-18. I used a pair of large gland pliers, which did the trick.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #5 of 5 Old 10-20-2011, 09:07 PM
78FordF150
1983 CJ7
^This times Three
Unsrew the cap and before you pull the shifter up fish the pin out from the side.
78FordF150 is offline
t18 tranny removal rdoria2002 Jeep CJ Forum 2 09-04-2011 12:13 AM
clutch replacement, removal of Tranny/TC help neals80 Jeep CJ Forum 17 03-18-2011 03:15 PM
Tranny removal Popper Jeep CJ Forum 3 06-14-2010 08:53 AM
Engine/Tranny Removal Q's BigMike20 Jeep CJ Forum 1 08-31-2004 06:37 PM
Tranny Removal Jwhit Jeep CJ Forum 3 02-24-2003 11:33 PM
