T-18 question - JeepForum.com
post #1 of 11 Old 02-24-2013, 12:49 AM Thread Starter
sean112280
1997 XJ Cherokee
T-18 question
What fluid do I put in it? I know it's kind of a rookie question but never had one before this jeep
1974 CJ 5 SBC-SOLD
1997 XJ
XK/WK Owners Group #11
sean112280 is offline
post #2 of 11 Old 02-24-2013, 05:59 AM
ADDZ71
1979 CJ7
From a viscosity standpoint it is easy 85-90W Gear Oil. The GL rating is where it gets hard. Older transmissions like the T-18 have some yellow metal parts i.e. Brass. Search and you will see many threads on here and other forums on this issue. From the factory it recommended GL-4 which is only offered that I found at NAPA. You may be able to get it online from somewhere but in town stores will be NAPA and I would call in advance since it is not always on the shelf or not enough. You will need I think just more than 2 quarts.
ADDZ71 is offline
post #3 of 11 Old 02-24-2013, 07:26 AM
82JeepCJ7
1982 CJ7
A T-18 holds 2 quarts. I'm running 50wt motor oil in mine. This was recommended to me by a transmission builder. Normally these transmissions are used in heavy trucks where the stress on the gears requires the heavier gear lube. In light weight Jeeps, that is not the case. Using 50wt motor oil will make it shift easier, especially when its cold outside.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #4 of 11 Old 02-24-2013, 09:37 AM
only in a jeep cj
Yep, I use motor oil in all my transmission and haven't had any problems in the 20 years and hundreds of thousand mile later.
But, I haven't had a T18 yet, so tha'ts all I say.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #5 of 11 Old 02-24-2013, 10:28 AM
CSP
50 wt motor oil is about equivalent to a 80wt gear oil. The way viscosity is measured in motor oil isn't the same as gear oil. Some people might think 50wt is too light, but that's why it makes a viable choice. You wouldn't want to use it in an axle application as it wouldn't stand up the pressure a hypoid gearset sees, but it's fine in a transmission.
CSP is offline
post #6 of 11 Old 02-24-2013, 10:33 AM Thread Starter
sean112280
1997 XJ Cherokee
Thanks everyone! I appreciate the help
1974 CJ 5 SBC-SOLD
1997 XJ
post #7 of 11 Old 02-24-2013, 10:41 AM
brownbagg
1930 MK Compass
isuzu trooper transmission take 30 wt, and it works fine
brownbagg is offline
post #8 of 11 Old 02-24-2013, 11:06 AM
roadhog304
1973 CJ5
Does the 50 wt oil have any effect on the brass in the trans? Can you also use it in the transfer case?
1973 Jeep CJ5 Amc powered resto-mod
1976 Jeep CJ7 GM powered future 1 ton crawler
roadhog304 is offline
post #9 of 11 Old 02-24-2013, 11:21 AM
CSP
No, the 50wt motor oil doesn't have the sulphur based additive that eat yellow metals. Those additives are only found in GL5 gear oils (not found in synthetic GL5 gear oils) and are what allow those gear oils to withstand the pressures that the ring and pinion see.
CSP is offline
post #10 of 11 Old 02-24-2013, 02:50 PM
roadhog304
1973 CJ5
Thanks. So is it okay to use the 50wt in the transfer case?
post #11 of 11 Old 02-24-2013, 03:21 PM
CSP
Yes, the tcase is not a hypoid gear case (just axles are) so it's ok there too.
CSP is offline
