T-18 Ford to 304AMC - JeepForum.com
post #1 of 6 Old 01-07-2012, 09:24 PM Thread Starter
pacmanCJ5
1978 CJ5
T-18 Ford to 304AMC
Currently i have the 304 with a T-150/ Dana20 set up and i have a T-18 with granny 1st out of a ford sitting in the shop. Question is what all do i need to make it work? Will the T-18 bolt up to the bell housing and t-case i have or do i need adapters? I also have the t-case out of the ford i believe its a 205,(its all out of a 78' 3/4ton) should i go with this t-case or the model 20 i am currently running? Any input is greatly appreciated! thanks.
pacmanCJ5 is offline
post #2 of 6 Old 01-07-2012, 10:52 PM
har99
1979 CJ7
Here are some helpful links regarding T18s, short shaft kits, and a short shaft rebuild. Read the Novak link for the answer to the bellhousing question. The first link was a recent T18 post you can reference. I think these will help.
http://www.jeepforum.com/forum/f8/t1...oding-1305650/
http://www.novak-adapt.com/knowledge/t18_t19.htm
http://www.jeepforum.com/forum/f8/t18-t18a-1299749/
http://www.jeepfan.com/projects/t-18...hort-shaft-kit
http://www.partsmike.com/store/store...on=show_detail
har99 is offline
post #3 of 6 Old 01-07-2012, 10:53 PM
taylorjb
1973 CJ5
Great swap. Good place to start:
http://www.novak-adapt.com/knowledge/ford_to_amc.htm
Good luck.
JT
Denver, CO
taylorjb is offline
post #4 of 6 Old 01-07-2012, 11:06 PM
1986cj
You need a adaptor for the Dana 20 and a new mainshaft for the T18 to mate to a Dana 20 or 300, the Ford input (main drive gear, short shaft) will work fine with the right pilot bushing. The Ford T18 with the 205 is a driver side drop, CJ needs a passenger side drop.
1986cj is offline
post #5 of 6 Old 01-07-2012, 11:29 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
If you need a clutch, the whole kit from LUK is P# 01-015. OR if you need just the jeep to Ford pilot bushing it's Novak # P3181176B @$17.60
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #6 of 6 Old 01-08-2012, 01:11 AM Thread Starter
pacmanCJ5
1978 CJ5
thanks for the input and the links! Lots of help!
ford T18 rconner Jeep CJ Forum 4 01-26-2010 07:30 AM
Ford box behind the box of my 84 CJ7?????help thedink Jeep CJ Forum 8 01-28-2008 01:52 PM
Ford T18 into a CJ? CjinPA Jeep CJ Forum 3 02-07-2007 03:12 AM
Ford T18 JOKER4INK Jeep CJ Forum 2 10-22-2005 03:55 AM
ford 8.8 in my 83 cj7 Big-L Jeep CJ Forum 2 05-30-2004 09:23 AM
