T-176 Reverse Idler Gear Shaft Leak-Help! - JeepForum.com
post #1 of 15 Old 06-03-2010, 06:03 PM Thread Starter
Bellerophon
1980 CJ5
Any suggestions on what is causing a drip leak emanating from the reverse idler gear shaft on the front of a T-176? Is there an oil seal on this shaft? Can the leak be stopped from the outside?
Bellerophon is offline
post #2 of 15 Old 06-04-2010, 12:51 PM Thread Starter
Bellerophon
1980 CJ5
bump to top
post #3 of 15 Old 06-04-2010, 01:26 PM
jeepwhore
I don't remember there being a seal in there but it's been a year since I was last inside one. Is it leaking while in the Jeep or is this not in a running vehicle? The only thing I can think of would be if it sat with water in it and rusted the shaft. If you noticed the leak while it was out of the Jeep, I think there is a gasket that goes between the trans and bellhousing. That might be what seals it and with the bellhousing removed it allows it to leak.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #4 of 15 Old 06-04-2010, 04:11 PM Thread Starter
Bellerophon
1980 CJ5
Yes, it does leak while in use in the vehicle. I don't see a seal in the exploded view of the T-176. A bell housing gasket would surely make sense. Was this standard for a 1980 CJ and T-176? I don't see this gasket in the T-176 gasket rebuild kit.
post #5 of 15 Old 06-04-2010, 05:13 PM
243
1978 FSJ Cherokee
I did not have a gasket on my T176 and there is no seal on the countershaft itself;and, it was a snug fit in the case. How do you know it is leaking at that location, is the trans out of the Jeep?
Dave's 78 Build
243 is offline
post #6 of 15 Old 06-04-2010, 06:27 PM Thread Starter
Bellerophon
1980 CJ5
It was out, now it is back in. I know for sure that is the source of the leak since I could see it leak from that area when the tranny was on the bench. I tried to fix it with sealant on the outside before reinstalling the tranny, but it still puts out some seepage when driving. I figured this was a common occurrence. I guess it isn't.
post #7 of 15 Old 06-04-2010, 07:00 PM
243
1978 FSJ Cherokee
The only reasons I cold see it leaking from the countershaft would be it was rebuilt and the pin was not put in the opposite end of the shaft and it spun and enlarged the hole, the countershaft was corroded in place and when it was driven out during a rebuild it clearanced the hole in the case, or, it has a lower viscosity gear oil than 75-90.
Dave's 78 Build
243 is offline
post #8 of 15 Old 06-04-2010, 07:53 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Not sure how that shaft seals. I wonder if you could cut an O-ring groove in the shaft where it passes thru the case?
BESRK is offline
post #9 of 15 Old 06-06-2010, 12:29 PM Thread Starter
Bellerophon
1980 CJ5
Negative on the oil viscosity as it has 80W-90. If the hole in the case was somehow enlarged over the course of its life, and then made worse during a rebuild, although there is no discernable sign of this variance in tolerances from the outside of the case, can't the trickle leak be contained by some application to the outside of the case around the shaft?
post #10 of 15 Old 07-27-2013, 07:35 PM
BSetera
1980 CJ5
Old Thread Revival...
Has anyone else had this problem? I am having the same problem and was wondering if some RTV on the bellhousing might work to seal it up. Just wanting to make sure I am not going to be messing anything else up by doing this.
Thanks,
Brad
1980 Jeep CJ5
Currently in frame-off restoration
BSetera is offline
post #11 of 15 Old 07-27-2013, 07:58 PM
LumpyGrits
It works for me with the counter shaft seal on my T-5.
LG
LumpyGrits is offline
post #12 of 15 Old 07-27-2013, 08:21 PM
rplivin
I just rebuilt my t176 and the reverse shaft was no where near as tight in the case as the other. So I put it around both sides front and back of mine. I don't see any issues as when I tore it down it had it on there.
rplivin is offline
post #13 of 15 Old 07-28-2013, 08:29 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The cluster countershaft is an interference fit. The shaft should have to be driven into the casing with a couple of light taps from the rear. A leak would indicate excessive clearance between the shaft and the casing, a cracked housing, or a scratch or other damage allowing the oil to pass between the two surfaces.
If you feel the shaft installed correctly and feel all is mechanically sound, you can clean and fill the void with silicone. If the hole mates to a flat surface on the bellhousing, smear a light cote around the area there as well.
jeepdaddy2000 is offline
post #14 of 15 Old 07-28-2013, 09:10 AM
MoC
X2
I would drain it, clean up every speck of oil with brake cleaner, and use Right Stuff. It's a little stronger than silicone. It's a band aide fix..
MoC is offline
post #15 of 15 Old 07-29-2013, 08:09 AM
BSetera
1980 CJ5
I cleaned up both surfaces yesterday (transmission & bell housing), applied black rtv and it has worked up till this morning where it has leaked immediately before. The jeep is not running, so only time will tell. I'll try and remember to update when I get everything running. Thanks again for all the help.
Brad
1980 Jeep CJ5
BSetera is offline
Dana 20 Rear Output Shaft Leak Fireman101 Jeep CJ Forum 1 10-03-2010 08:22 PM
CJ5 Steering Shaft Coupling Leak cpmarshalljr Jeep CJ Forum 1 10-28-2009 06:21 PM
CJ5 goes into gear but will not move fwd or reverse saintk Jeep CJ Forum 10 08-27-2009 10:22 AM
Reverse Gear In My Tranny Demolished! d_wagscj7 Jeep CJ Forum 10 03-26-2009 09:53 PM
rough idle except in reverse gear tacodruff Jeep CJ Forum 5 08-24-2005 11:55 AM
