t-150 transmission - JeepForum.com
post #1 of 8 Old 03-14-2009, 11:51 AM Thread Starter
newjeepowner
t-150 transmission
first..be nice as I've never even looked at a transmission before...
my cj-7 is leaking gear oil and it seems its coming from the top. I pulled the boots off the stickshifts and it looks like it a bad gasket (right at the top). I also noticed a metal 'valve' off some sort (don't know what else to call it but the top of it can be spun around-its about the size of a bolt head) that fluid might also be coming from.. can anyone let me know what this this is technically called, what it does and if it also might be the problem?
newjeepowner is offline
post #2 of 8 Old 03-14-2009, 12:13 PM
bigjoe
1977 CJ7
Well it sounds like a breather or vent for the tranny. If that helps. Do you have a picture of what your looking at. It may help to ID the part.
Seems like everyday is a Monday.
77' CJ-7 83' Chevy K10
bigjoe is offline
post #3 of 8 Old 03-14-2009, 12:42 PM Thread Starter
newjeepowner
i you are right...i think its a breather. do these ever create a leak? seems like the head gasket but just thought id ask. thanks
post #4 of 8 Old 03-14-2009, 01:53 PM
rkbell
1977 CJ5
You shouldn't be blowing gear oil through the vent. It shouldn't be leaking from the top cover gasket either.
You might want to either drain & refill the tranny or pull the top cover (only 8 bolts, easy to get to with your floor access panel removed. I say this because your tranny may have taken in water, especially if the jeep has sat without a top and you have a tear in your shift boot. Mine was like that and it was way overfull; looked like a banana milk shake in there (fluid was yellow and foamy).
If and when you pull the transmission top cover, it should look something like this (minus the yellow gunk you see here):
While the cover is off, throw another gasket on there unless the old one is in good shape still.
"We and the world will always be at war. Retreat is impossible. Arm yourselves for the conflict." Leif Enger
rkbell is offline
post #5 of 8 Old 03-14-2009, 03:20 PM Thread Starter
newjeepowner
ok- i think i'll get a gasket then pull the top. Is this a good place to get teh gasket? http://www.quadratec.com/products/52118_52.htm
Thanks again!
post #6 of 8 Old 03-14-2009, 03:35 PM
bigjoe
1977 CJ7
You may just want to try the local auto parts place first. They may have it in stock.
bigjoe is offline
post #7 of 8 Old 03-14-2009, 03:46 PM
rkbell
1977 CJ5
x2 on Bigjoe's post. Most catalog stores are probably going to sell the complete gasket set for your T-150; not expensive but I'd go to your local parts store and see if they can get it for you, you may get it quicker and won't have to pay shipping.
Don't forget to change your fluid if it's been in there awhile or you're not sure how long it's been in there. If you fill it from the top while you have the cover off, make sure you don't overfill it (shouldn't come above your fill plug opening on the right (passenger) side of your transmission.
The good thing about removing the top cover is that you'll be able to pretty well visually inspect the inner workings.
rkbell is offline
post #8 of 8 Old 03-14-2009, 04:35 PM Thread Starter
newjeepowner
super...thanks guys...i'll try local...i've been filling it from the side on the passenger side (hex key nut) since its been leaking...(hopefully only from the top is the problem!)
AMC TH-400 Transmission Rickstitans Jeep CJ Forum 1 01-25-2009 07:49 PM
AMC TH-400 Transmission Rickstitans Jeep CJ Forum 1 01-25-2009 01:17 PM
TRANSmission. Etchandy Jeep CJ Forum 4 08-22-2007 06:35 AM
What transmission do I have? '79 CJ7 gmshades Jeep CJ Forum 1 07-09-2007 12:58 AM
Transmission for a 350 wannachrist Jeep CJ Forum 15 06-27-2004 08:09 AM
