t-150 Clutch size - JeepForum.com
post #1 of 3 Old 09-10-2008, 03:26 PM Thread Starter
CJ Runner
1978 CJ5
t-150 Clutch size
I have a 1978 CJ-5 w/ a 304 and t-150 transmission. I ordered an AMC 360 to put in instead and a new clutch kit for the t-150. I got the clutch today from autozone and the clutch diameter was 9 inches. I know it's not the correct clutch b/c it has more than 10 splines. The old clutch I pulled measures almost 10.5" I don't have the flywheel for my 360 yet so:
1) Google search on 2603357 says it's a t-150 so what size clutch is stock?
2) Is the AMC 360 flywheel bigger than the 304's flywheel
3) Will a bigger clutch (more surface area) be beneficial and if so which clutch can I use?
Thanks!
CJ Runner is offline
post #2 of 3 Old 09-10-2008, 06:21 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Advance Adapters used to have a listing of clutch size/splines for the AMC engine/tranny combos. I'd run a 10.5" clutch setup with the 360.
BESRK is offline
post #3 of 3 Old 03-11-2010, 10:39 PM
golftracerguy
A little off the trail here, but I just bought a 360 from a 76 J10 with a T18 low gear tranny, missed the tranny by a day, but wanted to know what clutch kit I should buy for the t176/360 marriage. It still has the clutch still on it but I want to replace it before I put it in my project. Any help will be appreciated!
Chuck
golftracerguy is offline
clutch: different bore size for master and slave cylinder kercher Jeep CJ Forum 0 10-09-2009 10:24 AM
Clutch Size? xeroOTG Jeep CJ Forum 2 08-14-2009 03:29 PM
Clutch Master thread size? green cj 78 Jeep CJ Forum 0 06-29-2009 08:39 AM
Clutch bolt?? Size? Bear-Olemiss Jeep CJ Forum 0 10-19-2008 07:04 PM
Clutch size... collinpyle Jeep CJ Forum 5 08-11-2006 05:21 PM
