Switching my 3 inch body lift with a 1 inch - need advice - JeepForum.com
post #1 of 4 Old 03-31-2011, 02:23 AM Thread Starter
MemphisCJ7
1983 CJ7
I dislike having the body that far off the frame.
My current plan is to just drink alot of beer, unbolt the current mounts, and bolt in the new ones.
The last 6 years with this jeep have taught me that there is no way it's going to be that simple.
Any words of warning?
What is most likely to go wrong?
It also has a 3 inch suspension lift and a 1 inch shackle lift that I will be leaving on if that matters.
Thanks for your help.
MemphisCJ7 is offline
post #2 of 4 Old 03-31-2011, 06:34 AM
neals80
1980 CJ7
well I just removed my 2.5 inch and went to stock...looks and rides better...
Soak the bolts all 9 of them...with PB blaster etc...
look at your clutch assembly/bell crank, they should have moved it higher for the 3in lift....you will need to adjust that first for the 1 inch...
I used 3 jacks and did one side at a time per Daystars instructions....
I had to sawzall off 6 bolts..and cut into the square bolt retainers remove the old square nut and bolt welded and rusted in place...I made my own square bolts, taped new threads and used of course shorter grade 8 bolts.....
Just a timely project if you have issues with bolts.....if not you can finish in a few hrs with no issues..and yes beer helps....
I am very happy with removing the body lift the natural look is nicer
Let me know what else I can help you with...
Good luck
Neal...
Neal Trombley
1980 CJ 7
SW FLORIDA
IF I WANTED A HUMMER I WOULD HAVE CALLED YOUR GIRLFRIEND!!
neals80 is offline
post #3 of 4 Old 03-31-2011, 06:55 AM
twoleos617
Neal gives good advice here.
its not a hard job at all but depending on hardware, it can be a little time consuming.
again, soak the hardware every night a few days before.
loosen hardware on all sides to allow the body to move and remove one side at a time.
might want to disconnect your fuel filler hoses too before hand.
and yes, some good tunes and beer will be your best tools!
take before and after measuements and pics for us to see!
edit: steering shaft may have been lengthend/replaced or just slip.
twoleos617 is offline
post #4 of 4 Old 03-31-2011, 10:55 AM
PERK
your clutch rod would have been lengthened, you will need to go back to a stock one and, your radiator should have been lowered, you need to remount to the stock holes. fuel filer hoses may have been replaced with longer ones
PERK is offline
1 inch body lift and 3/4 inch shackle lift? bucs1fan Jeep CJ Forum 6 09-29-2009 01:21 PM
1 inch body lift jallen760 Jeep CJ Forum 5 10-25-2008 01:21 PM
4 inch Rough Country Lift on 28 inch tires CrazyFlippinCJ7 Jeep CJ Forum 16 03-02-2008 03:09 PM
Does anyone have any pics of a jeep with a 6 inch or more lift and 35+ inch tires? jeepcj7 Jeep CJ Forum 10 03-23-2003 09:39 AM
2 inch body lift crotz83 Jeep CJ Forum 4 12-17-2002 07:25 PM
