swing out tire carrier - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > swing out tire carrier
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDJeep Wrangler Complete Gear Upgrade Kits with Installs and
Unread 02-20-2015, 02:17 PM   #1
skinhinajeep
1979 CJ7
I have looked for the answer to my question but cant find it on here, I want to duplicate or come close to the original spare tire carrier but I cant find out what size of square tubing I should use, would it need to be 2" square or could 1 1/4" square work? I know it depends on the weight on the tire Im just trying to get a rough idea to see what I can get from my friend that has some spare square tubing.
skinhinajeep is offline   Reply With Quote Quick reply to this message
Unread 02-20-2015, 02:36 PM   #2
CSP
Definitely smaller than 1". Going strictly off of memory I'm thinking 1" is more like it.
CSP is offline   Reply With Quote Quick reply to this message
Unread 02-20-2015, 03:04 PM   #3
Ken4444
Corripe Cervisiam
Ken4444's Avatar
2" is too wide. Without measuring it, I would guess the square tubing is about 1-1/4" or 1-1/2"wide.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote Quick reply to this message
Unread 02-20-2015, 03:54 PM   #4
ChiefSpoonS
1979 CJ7
I'll check when i get home tonight
Shoot me a text around 7 pm est
704-500-6354
ChiefSpoonS is offline   Reply With Quote Quick reply to this message
Unread 02-20-2015, 04:13 PM   #5
TheK12
Junior Member
It's 1-1/4".
TheK12 is offline   Reply With Quote Quick reply to this message
Unread 02-21-2015, 08:21 AM   #6
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by TheK12 View Post
It's 1-1/4".
yep! That's right. Here's a photo of my 1985 carrier showing 1.26". Keep in mind it has 2 layers of paint. The photo was taken sideways and then rotated so you can more easily see the numbers on the caliper display.
Unread 02-21-2015, 11:22 AM   #7
Erik719
Erik719's Avatar
1983 CJ7
Do you want an original? I have one.
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline   Reply With Quote Quick reply to this message
Unread 02-21-2015, 12:49 PM   #8
STJP
Street Jeep
STJP's Avatar
There are differences in top and bottom square tube dimensions on oem carrier. Also if you buy an OEM make sure it comes with ALL the mounting pieces. Look at diagram in FSM to see all pieces. All are needed to support tire weight.
STJP
STJP is online now   Reply With Quote Quick reply to this message
Unread 02-22-2015, 08:05 PM   #9
skinhinajeep
1979 CJ7
Hey Ken what is the thickness of the tubing?
Unread 02-23-2015, 07:16 AM   #10
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Fairly thin: .084 inches measured at the end where latch handle is located.
