sway bar stud - JeepForum.com
post #1 of 8 Old 11-06-2002, 03:02 PM Thread Starter
rustyCJ
sway bar stud
i was at a friends today helping him put in his lift. we tried doing it a few weeks ago but even with 4 ft cheaters the spring main eye bolts were rusted too bad to break loose. so after two weeks of putting penetrating oil on them everynight and 4ft cheater bars they all broke loose. everything went fairly smooth, the rear springs and shocks are in but when attempting to remove the last nut, the sway bar nut, he snapped the stud off with the nut.
will he have to get a whole new spring plate or is that stud replaceable?
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #2 of 8 Old 11-06-2002, 10:31 PM Thread Starter
rustyCJ
anyone know the answer, i just got offa the phone with him and he wants to try to finish everything in the morning.
so can you change out a broken stud or do you have to get a new plate?
rustyCJ is offline
post #3 of 8 Old 11-07-2002, 05:41 AM
TG CJ7
I dont think plates are that expencive, you could just buy a new one. If your planning on getting it done today, try drilling out where the stud goes, tapping the hole, and then put in a grade 8 stud. Thats what I would do if you had to finish it today.
Good luck
Tim
1979 CJ7 Renegade 304, 3spd, 2.5 BDS lift, Hedman headers.
Check it out
TG CJ7 is offline
post #4 of 8 Old 11-07-2002, 07:45 AM
DaveFL
DaveFL's Avatar
If it is a stock spring plate the bolts are not replaceable. Im 90% sure of this. Ive got a plate sitting in my truck right now when I get a chance Ill double check.
I'm replacing all my spring plates on my CJ, most of the plates seem to have the sway bar link stud weilded in, I think the warrior plates with skid protection are the only ones I have seen that are removable.
Front plates sell for average $18-30 each according to what brand or if you want skid protection on them. The cheapest I think I have seen so far are at http://www.rigidsteel.com/.
Hope this helps.
______________________________
03 Rubicon
Nth 6"LA lift, TT, Stinger/Slider Combo, Superwinch EPI9000, Durango Front & Rear, ORF Tire Carrier, Independent Locker Mod, 15x8 Crager Locks, 35" MT MTZ,Rock Hard Parts trail Cage, AEM Dry Flow, Viking Fastback Top.
DaveFL is offline
post #5 of 8 Old 11-09-2002, 11:57 PM
80cj
80cj's Avatar
1980 CJ5
He might try driving the Jeep without the sway bar. He might find that he doesn't need it. My friend took the sway bar off his YJ when he installed his lift and it handles very well even on a winding mountain road.
80cj is offline
post #6 of 8 Old 11-10-2002, 01:51 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I am running without sway bars or track bars on my YJ. Just a set of springs holding my axles in place, and I have no major problems.
I was quite nervous at first about the setup not having all the factory links .. but after driving it on the street for a day, I said screw the swaybar and track bar .. and they haven't been seen since.
Now, I am also in SOA configuration .. and still no ill-effects.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #7 of 8 Old 11-10-2002, 02:52 PM
80cj
80cj's Avatar
1980 CJ5
A helluva lot more articulation too, without that sway bar. The increase in articulation and resulting increase in traction is very significant.
80cj is offline
post #8 of 8 Old 11-10-2002, 06:34 PM
GTSCJ
Most lift springs don't need a sway bar. The Jeep will probably ride better wih out it.
GTSCJ is offline
T18 Bellhousing Stud Kman1983 Jeep CJ Forum 2 08-22-2009 06:46 PM
Sway bar stud cwsenn Jeep CJ Forum 3 04-19-2008 06:32 AM
Torque Stud CJ51973 Jeep CJ Forum 2 02-17-2006 07:24 AM
torque stud coyote69 Jeep CJ Forum 6 10-13-2004 04:52 PM
Torque stud coyote69 Jeep CJ Forum 0 10-01-2004 06:58 AM
