Swapping trac-lock for open differential AMC 20 ?? - JeepForum.com
 5Likes
post #1 of 16 Old 08-22-2017, 11:20 AM Thread Starter
Hoover7
Junior Member
Hoover7's Avatar
Hi everyone, I have a 1982 AMC 20 with the dreaded DD stamp on the axle boss (2.73 w/ Trac-Lock), and looking to install a more favorable gear set. I have access to a used 3.54 ring and pinion set, along with the appropriate carrier. However, the replacement carrier is for an OPEN differential. Are there any issues that would prevent replacing the trac-lock diff with an open differential?
Although this has probably been addressed in another thread, I haven't had any luck finding an answer. Thanks for your help!
Hoover
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild in progress
83 CJ8 Scrambler, 258, T176, Cliffordized, cam and headers
84 CJ7 Renegade, 258, T5, Weber 38, Borla headers
Hoover7 is online now
post #2 of 16 Old 08-22-2017, 11:27 AM
80cj
80cj's Avatar
1980 CJ5
It would swap in. Get a installation kit from some place like Randy's Ring and Pinion. What about the front?
STJP likes this.
80cj is online now
post #3 of 16 Old 08-22-2017, 11:50 AM
LumpyGrits
Cj
Trac-loc is almost an open diff.
Do the swap and put a lock right in.
Hope you're going with 1 piece axles.
LG
80cj likes this.
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #4 of 16 Old 08-22-2017, 12:16 PM
80cj
80cj's Avatar
1980 CJ5
LG
Trac Lok is an open diff with clutches.
80cj is online now
post #5 of 16 Old 08-22-2017, 01:45 PM
JoonHoss
2011 JK Wrangler
...That are usually worn out, and have non-correct/absent friction modifier in the fluid, which basically leaves you with and open diff.
Hoss
John Strenk likes this.
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #6 of 16 Old 08-22-2017, 02:32 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Hoss
That is what happened to mine.
Put in the friction modifier which caused the track lock to start working so well that it spun the hub on the passenger side.....
Go figure.
John Strenk is offline
post #7 of 16 Old 08-22-2017, 06:02 PM Thread Starter
Hoover7
Junior Member
Hoover7's Avatar
Appreciate the quick reply, 80cj. My primary concern was potential differences between the trac-lock and open differential housing. I'm really glad to know I can install the open diff for the TL without added difficulty. Thanks also for turning me on to 'Randy's ring and Pinion'. I'll be in the market for new front and rear bearing sets/shims when this project comes together. And to answer your question, I'll be replacing the D30's gear set with a matching 3.54 ring and pinion with an appropriate carrier as well.
LG
I agree with you LG! I just replaced a spun 2-piece axle on my 84 with a pair of Mosers, and so far so good. However, will likely run the original axles on this 82 until they quit on me. That is of course, unless I win the powerball.
Go figure.
Unfortunately, John, this 82 hasn't rolled on it's own since Sept 2000. I was T-boned by a tipsy coed in Baton Rouge and subsequently flipped and ejected. I was very fortunate, and walked away. Odometer read 63K, and those were easy miles. As such, I'm betting the TL differential and clutch discs are in pretty good shape. If anyone's looking for a matched set (D30 & AMC20) of 2.73's with a TL rear, I'll be happy to oblige once I've finished the swap!
Thanks for the input and quick answers, guys!
Hoover
post #8 of 16 Old 08-22-2017, 06:19 PM
80cj
80cj's Avatar
1980 CJ5
I believe the carrier break for a Dana 30 axle is 3,73 and up and 3.54 and down. So I think you're set as far as the front carrier is concerned.
80cj is online now
post #9 of 16 Old 08-22-2017, 06:46 PM Thread Starter
Hoover7
Junior Member
Hoover7's Avatar
Thanks, 80cj, that's the same information I've come across as well. I appreciate the verification!! The front and rear 3.54's I'm looking to pick up are still attached to the carriers, and are on the table for $100. Although I'd be more interested in going to a 3.73, I just can't argue the price! And I won't be running anything bigger than a 31 inch tire for the foreseeable future...
post #10 of 16 Old 08-23-2017, 01:59 AM
80cj
80cj's Avatar
1980 CJ5
I ran 31's with 3.54 gears and that's a good combination. Hope the gears are in good shape with no pits in the teeth.
Hoover7 likes this.
80cj is online now
post #11 of 16 Old 08-23-2017, 05:57 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The only difference (as it applies to the R+P swap) is the carrier face may be a different distance from the center line in comparison to the old carrier.If you were doing just a carrier swap chances are you would have to adjust the backlash on the new unit.
Installing the open carrier is an improvement in my eyes. TL's have an abysmal failure rate.
Your speedometer will be a bit (lot) off. You will want to score the appropriate t case speedo gear to offset the gear swap. perhaps the seller has his old one.
Remember to insure you get a good picture during your set up.
Hoover7 likes this.
bazinga
jeepdaddy2000 is offline
post #12 of 16 Old 08-23-2017, 08:41 AM Thread Starter
Hoover7
Junior Member
Hoover7's Avatar
Thanks for the insight, JeepDaddy. I've re-built engines and comfortable with working of most of the mechanical systems on my jeeps, but differential work has always remained an enigma. In preparation, I've been reviewing several threads and reading books on the subject, and looking forward to learning how to set a differential up on my own. And I hadn't even thought about the speedo differences- I'll inquire about the speedo drive gear when I speak with him! Thanks!
Hoover
post #13 of 16 Old 08-24-2017, 08:23 AM
jeepdaddy2000
1971 CJ5
The actual installation of the R+P isn't hard. The issue is the ability to read the picture and figure out the proper adjustment of the pinion (depth) and/or the carrier(backlash).
If both gear sets are Dana, then you can use the pinion markings, do the math, add or subtract from the old shim pack, and get a starting point.
A clam shell style bearing remover is really helpful, but they are expensive and have limited uses beyond transmission/ t case and R+P work.
The one thing to remember when setting up used gears is to get a good picture, and not to worry about the backlash.
bazinga
post #14 of 16 Old 08-24-2017, 10:48 AM
80cj
80cj's Avatar
1980 CJ5
True. Unless you have the luxury of being able to measure the BL of the old gearset before removal from the old housing. In such a case, Measure the BL at 3 points around the circumfirence of the ring gear and make a note of it.
80cj is online now
post #15 of 16 Old 08-24-2017, 03:09 PM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
I took my trac-lok that was worn out and took it to the axle shop and it was an easy job to switch out clutches and add n the modifier and have it functional in ust a few hours. Not saying it's a great limited slip scenario but it sure beats having nothing at all. Limited slip takes a little bit of finesse to get to work well on a trail as opposed to the brute force of a full Locker but they are useful 4 light off duty usage.
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
