Swapping Disc Brakes from 81 Dana 30 to 76 Dana 30 - JeepForum.com
post #1 of 3 Old 05-10-2007, 11:24 AM Thread Starter
PortlandCJ76
Hi,
New to the forum here and I have appreciated all the great info here. I've read a lot of threads on Dana 30 disc conversions and Terry Howe's write-up as well.
I have a chance to buy a complete 1981 Jeep Dana 30 axle. I want to swap the discs onto my 76 CJ-7. I just installed new bearings on my drum Dana 30 and I want to keep my six-bolt hubs. I don't want to have to buy new bearings, so I don't want to use the '81 spindles (some guys here have mentioned swapping everything forward from the ball joints)
Can I just install the knuckles and rotor assembly from the '81 Dana 30 onto my '76 Dana 30? Or do I need to swap spidnles, hubs, buy new bearings, etc..?
Thank you for your help!
PortlandCJ76 is offline
post #2 of 3 Old 05-10-2007, 11:29 AM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
It's not just the 5 bolt lockout that is the difference. Around '79 or so the disc brake caliper bracket switched from the 6 bolt flavor that the old 11" backing plates used over to a 2 bolt. I don't think the 2 bolts line up with the old 6 bolts, so you'll need to go ball joints out. Those bearings might still work, though, as I think the hub itself was unchanged internally other than the 5 bolts for the lockout instead of 6 externally.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #3 of 3 Old 05-13-2007, 04:11 PM Thread Starter
PortlandCJ76
thank you very much for the info
1985 CJ8 swapping in Dodge 1 ton Dana 44 front and Dana 60 rear?????????? JeepScrambler Jeep CJ Forum 8 05-21-2012 06:30 PM
86 CJ7 rear Dana 44 wants Disc brakes BlueRubiconrich Jeep CJ Forum 8 11-08-2009 09:50 AM
Swapping a T18 and Dana 300 into a CJ5 jumpalt2 Jeep CJ Forum 4 04-28-2008 06:02 AM
Swapping a Dana 44 into my '79 CJ-7 Matt in TN Jeep CJ Forum 11 08-17-2005 06:40 PM
Disc brakes for Jeep Dana 25 front end greenloafunlimited Jeep CJ Forum 0 07-08-2002 07:31 PM
