Swapping in AMC V8, but have some questions - JeepForum.com
post #1 of 38 Old 05-25-2013, 09:21 PM Thread Starter
Offroaddaddy
Hey all,
First time installing an engine, and have some questions, that I would like to get some confirmations on and a little re-assurance
I appreciate the help...
First pic, I have installed the flywheel, torqued the 6 flywheel bolts to 105ft.lb. Now where the pilot bushing sits, see the red arrow? doesn't look like the pilot bushing will sit flush as the tube where the transmissions input shaft goes seems to be sticking out about 1/8" or 3/16" - is this a problem?
Second pic: I have installed an edelbrock rpm air gap manifold. Instructions are not specific enough for me to understand. Is this where the heater hose from the heater core would enter the manifold? if yes, then I need to get some sort of fitting/adapter in order to attached the heater hose.
Pic 3: Is this where the temp sensor would install?
Pic 4: Oiler sender here?
Thanks again for your help and patience. Just want to make sure I am doing this right.
Paul
Offroaddaddy is offline
post #2 of 38 Old 05-25-2013, 11:15 PM
only in a jeep cj
On your last pic, there is a 90 degree threaded adapter block, an oil pressure switch (for the choke plate ) and a oil pressure sender unit all in line, pointing back.
From Matt1981CJ7 via another thread
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 38 Old 05-26-2013, 12:06 AM
82JeepCJ7
1982 CJ7
2nd picture, that is where the line goes to the heater core. The other hose will go from the heater core to the water pump.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #4 of 38 Old 05-26-2013, 07:24 AM
davbytrace
1979 CJ7
In pic 3, the water temperature sender should be installed in the hole that is on the drivers side of the water neck, or alternatively, into the rear of the water neck.
davbytrace is offline
post #5 of 38 Old 05-26-2013, 12:22 PM
motiv8ya
1979 CJ7
Here's the part # for a heater hose fitting I am using on my 401 with the same intake manifold. Are you using mechanical or electrical gauges?
motiv8ya is online now
post #6 of 38 Old 05-26-2013, 01:43 PM Thread Starter
Offroaddaddy
Thanks to you all, your help is really appreciated!
post #7 of 38 Old 05-26-2013, 01:44 PM Thread Starter
Offroaddaddy
Thx for the part number! I am using the original cj eletrical gauges.
Where did you end up threading your temp sender? Can you snap a shot?
post #8 of 38 Old 05-26-2013, 03:00 PM
82JeepCJ7
1982 CJ7
It is way easier to hook up the heater hose to the manifold if you use a 90 fitting instead of a strait fitting.
post #9 of 38 Old 05-26-2013, 04:40 PM Thread Starter
Offroaddaddy
Here is a pic of the pressure plate on, bellhousing, fork and throwout bearing. Alignment tool still in.
Does everything look right? Specifically how i have the throwout bearing installed?
post #10 of 38 Old 05-26-2013, 10:27 PM
82JeepCJ7
1982 CJ7
Yup, looks good. At least your throw out is facing the right direction...
Ask me how I know....
post #11 of 38 Old 05-27-2013, 03:11 PM Thread Starter
Offroaddaddy
LOL...don't feel so bad, I should share some of my stories with you...you'd probably smack me one!
post #12 of 38 Old 05-27-2013, 05:59 PM
motiv8ya
1979 CJ7
Stock temp sender for stock gauge is bottom left in pic (next to water neck), my after market mechanical gauge is installed in the right front of the intake manifold and runs through the firewall through a grommet in a plate I made to fill a factory hole.
post #13 of 38 Old 05-27-2013, 06:48 PM Thread Starter
Offroaddaddy
thanks for the pic...pic are worth a thousand words, thank you
since I am using the CJ original stuff, I could probably install the stock cj sensor where you have your mechanical sender? I am thinking yes ...
post #14 of 38 Old 05-27-2013, 07:12 PM Thread Starter
Offroaddaddy
thank you
What diameter heater hose did you use?
post #15 of 38 Old 05-27-2013, 09:09 PM
motiv8ya
1979 CJ7
5/8's heater hose. Yes you can put the factory sender on the opposite side with an adapter. The coolant port on the passenger side is a larger hole.
