swapped fuel tank and no fuel at carb - JeepForum.com
post #1 of 7 Old 12-05-2005, 06:45 PM Thread Starter
8679cjs
Any ways to trouble shoot a new tank after I've cranked it for a while? I swapped the tank and matched to lines back up from the vents and sending unit yet I cant seem to get fuel to the carb. Moses Ludel gives no real help nor does my haynes book give any trouble shooting techniques. Can you guys help?
8679cjs is offline
post #2 of 7 Old 12-05-2005, 06:55 PM
ballsout1
i`m gonna assume you have 3 lines exiting the tank..and three sizes. the biggest one is the feed to the pump...if you disconnect it at the pump can you siphon from it??? if you can its a pump problem.. if you cant its likely a kinked hose at the top of the tank...or your hoses got swapped around. remember ,the largest line is the feed line, if there swapped around its at the tank. did one hose seem unusually tight putting it on? i`m thinkin a kink somewhere.
ballsout1 is offline
post #3 of 7 Old 12-05-2005, 07:21 PM Thread Starter
8679cjs
i replaced the rubber lines at the tank so nothing had flares in the old rubber lines.
8679cjs is offline
post #4 of 7 Old 12-05-2005, 07:22 PM Thread Starter
8679cjs
i only had two lines from the sending unit
8679cjs is offline
post #5 of 7 Old 12-05-2005, 07:39 PM
plmoss21
If I am remembering this right there is only two from the sending unit but there are two more outlets on the side of the tank one goes to the vac. sys. resivourand the other goes to the rollovervalve. I will give you a tip, autozone.com has complete fuel line, vac. line, and electricial diagrams along with some other great useful info.
http://www.autozone.com/home.htm
look at the bottom right hand corner of this main page.
plmoss21 is offline
post #6 of 7 Old 12-05-2005, 09:54 PM Thread Starter
8679cjs
thanks alot dude! I will try switchng the lines getting alotta snow tonight...was hoping to be reading for snow. Hopefully its the lines and not the fuel pump. I never knew about that Autozone site. U da man
8679cjs is offline
post #7 of 7 Old 12-05-2005, 10:17 PM
JeeperJohn
If this is a used tank you might have a blocked filter. Most gas tanks have a filter on the end of the pick up tube.
JeeperJohn is offline
Bad TBI electronic fuel pump or problem with fuel tank? boomvader Jeep CJ Forum 5 01-18-2010 10:26 PM
Fuel float next to fuel tank migolito Jeep CJ Forum 4 01-10-2010 08:36 AM
CJ-7 1982 Carb, Fuel Pump & Tank frank vandelden Jeep CJ Forum 0 09-25-2009 01:56 PM
Tank is full, fuel gauge reads Half tank!?! martyweir Jeep CJ Forum 10 09-25-2008 06:55 AM
Installing Fuel Tank and Fuel Lines? How Hard? JeepFan07 Jeep CJ Forum 6 01-10-2008 06:49 PM
