Swapped Carter to a Weber 32/36 - Now What
| The Original 3/8" Ruffstuff Diff Cover! | Ruffstuff Axle Simple Swap Kit! | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
I swapped out my old Carter 2BBl to a nice new Weber 32/36, thanks to all the advice from this forum.
My question is now that I have unplugged the the carburetor from the computer do I have to do some sort of bypass or can I just leave it as is? I was looking at the Nutter Bypass but my wires are not the same color as the ones in the posts. I have Orange, Black and Brown coming from my distributor, no purple?
[COLOR="Red"][CENTER][SIZE="4"]I THINK I'M ADDICTED[/SIZE][/CENTER][/COLOR] (SOLD)2011 JK Unlimited - Rugged Ridge Stubby, smittybilt 10k Synthetic, Tuffy Concealed Carry Drawer, Tuffy Security Deck. |
#2 |
All your ECM controls now is the timing advance.
After I put the Weber on I just got an MSD 6T ignition module and never looked back. My ECM is completely out of the loop.
Vibration? Bump steer? Wandering? Read: Steering, suspension, and driveline basics. An article on how it works and where to look for problems. 83 CJ7, 4.1L 6cyl (4.0L bored .030" over), 35" tires, T-5 transmission, Dana 300 TC, Trussed AMC 20. |
#3 |
Did you need to bypass anything or just upgraded the ignition?
#4 |
Once you upgrade the ignition with an HEI, there is nothing else to do. You can actually unplug the wires going to the ignition module in the engine compartment (driver side near firewall under charcoal canister) and remove the entire emissions harness and ECU to clean things up a bit. With the Weber and HEI, there is absolutely nothing the computer will be doing for you now.
Good luck. Easy to do and engine compartment will look real clean without the extra wires. EDIT: I went with the DUI HEI and couldnt be happier. Easy, clean, and efficient.
1985 Jeep CJ-7 Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage. USMC 1999-2004 Semper Fi! Torchmate CNC Plasma Table Build / Projects |
#5 | |
I just upgraded the ignition... that bypassed it. I used the Team Rush upgrade with an MSD 6 ignition module.
#6 |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The brown wire is likely just a dirty purple one....
You need to hook the orange and purple wires at the distributor to the orange and purple wires at the ignition module, reset the timing and away you go.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#7 |
Agreed, there's no need for HEI unless you wanted to upgrade. When you wire your distributor directly to the ignition module with the ECU out of the loop like Mike says, the ECU doesn't do anything anymore and can be stripped out. It should take about 5 minutes to connect the 2 wires and pull out the ECU from under the dash.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress) 1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress) |
#8 |
My problem is that i=even if the brown is a dirty purple at the distributor, there is nothing that resembles a purple or brown at the ignition module??
#9 | |
Off Road Forever
What has someone put in yours?
#10 |
I don't know, I think I am going to go buy a new one so I can do the Nutter and be positive at what I am cutting
#11 |
Off Road Forever
Can you post a link to a photo of it, we can likely ID it easy enough.
#12 |
Sure, below are some pictures. I also noticed that the computer behind the dash said FORD on it?? Is that correct? Also when I am cutting these wires for Nutter do I cut them on the ICM and distributor side of the plugs?
![]() ![]() [IMG]http://i862.photobucket.com/albums/ab185/sandman73/100_2704.jpg[/IMG [IMG]http://i862.photobucket.com/albums/ab185/sandman73/100_2720.jpg[/IMG ![]()
#13 |
#14 |
Off Road Forever
Yup, Ford computer.
That looks proper. The plug on the jeep harness side only has the orange green and black, the purple is only over on the module side of the plug, so it needs to be cut there and a new wire added. (computer supplies the purple to the distributor.) I just add two new wires and twist them together to replace the orange and purple wires without messing inside the harness. You can't take out all the wires either or your reverse lights won't work...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
