swap tilt steering need help with wiring - JeepForum.com
post #1 of 8 Old 01-14-2010, 08:01 AM Thread Starter
Eighty8mike
1977 CJ5
I just swapped in a 1978 Camero steering column into my 77 CJ5. I have a few mods to do on the shaft nothing major. My problem is the wiring connection. What I need is to know is which wires connect from jeep wiring harness to new column. I think the wires controlling the blinkers hook up just fine. But the larger plugs don't plug into new column. I would greatly appreciate any and all help I can get on this.
Thanks
Eighty8mike is offline
post #2 of 8 Old 01-14-2010, 11:03 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Do you mean the one ones for the ignition switch? Maybe you need a different switch. I don't really know.
If the new column is a tilt wheel the connectors go on different I think. I'll hae to take a look.
Still got some time to take some pictures of your problem?
John Strenk is offline
post #3 of 8 Old 01-14-2010, 11:20 AM Thread Starter
Eighty8mike
1977 CJ5
Well the good news is I was able to take the switch off old column and put on the new column. With doing that I was able to get blinkers to work. However I cant get the key to go to the off position and remove from the switch. So I am taking it to a shop for them to check it out. Thanks for your reply tho!~
post #4 of 8 Old 01-14-2010, 04:20 PM
CJunk
I dont know if this helps, but for an 80's cj the ignition switch on the column is different for a tilt wheel vers a non tilt (harness still plugs in)
CJunk is offline
post #5 of 8 Old 01-14-2010, 10:09 PM Thread Starter
Eighty8mike
1977 CJ5
Your right, I dont understand what the difference is but......Ill have to order it from autozone. Thanks for advice!
post #6 of 8 Old 01-15-2010, 03:13 AM
John Strenk
1976 CJ5
The difference is the non-tilt column moves forward when twisting the key clockwise and the tilt column moves to the rear when turning the key clockwise.
post #7 of 8 Old 01-15-2010, 09:39 AM Thread Starter
Eighty8mike
1977 CJ5
Ok thanks for explaining the difference. As of now the column is at a local shop. Seems the key didnt want to come out and I have very limited tools and time not to mention zero know how! I will be sure to order that tilt switch.
Thanks
post #8 of 8 Old 01-18-2010, 04:48 PM Thread Starter
Eighty8mike
1977 CJ5
How about this one, anyone know about the parking brake set up? My 77 CJ 5 has no parking brakes, all the cables are there. I think my problem is where all three cables meet, parking brake lever, left and right side. Any suggestions would be welcome!
CJ7 Tilt steering weprint Jeep CJ Forum 1 01-27-2010 06:10 AM
Tilt Steering Wiring Diagram RetiredSERE Jeep CJ Forum 2 12-04-2009 03:21 AM
81 Tilt steering in a 76 CJ5 - wiring issue Davidpsalt Jeep CJ Forum 1 05-20-2009 04:11 AM
CJ Tilt Steering h2obuff Jeep CJ Forum 6 10-18-2005 06:23 AM
how to swap out steering column for tilt one edge1 Jeep CJ Forum 1 12-04-2003 07:12 AM
