Swap a chevy Dana 44 into a CJ? - Page 2 - JeepForum.com
post #16 of 22 Old 03-06-2007, 12:15 PM
John N
1981 CJ8
Castor on Chevy and Waggy front ends works for most without any adjustment.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #17 of 22 Old 03-06-2007, 12:24 PM Thread Starter
slacker92104
slacker92104's Avatar
Cool. What are my options for going to high steering. The axle I'm looking at has the flat top knuckles, but where do I go from there? Can I use the cj wide track linkage?
slacker92104 is offline
post #18 of 22 Old 03-07-2007, 11:55 AM Thread Starter
slacker92104
Somebody knows right?
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
post #19 of 22 Old 03-07-2007, 12:31 PM
Blthomas
Blthomas's Avatar
1979 CJ7
http://77cj.littlekeylime.com/flatop_knucles.html
The link goes over knuckles and stuff.
I would guess that your next step is some machining, getting some arms, and then choosing a linkage, wether it DOM and Heims, or a chevy linkage, or whatever.
I'm going to use Waggy linkage, Waggy knuckles, and a waggy axle. I believe I'll have to shorten the draglink, but it should work.
I may be completely speaking out my butt here. Just trying to remember what John N and Jeepskate were relaying to me a few months back.
79' CJ7 - 4" lift, 33's
81' CJ8 bone stock
80' Chief "S" 6" lift, 33's
Blthomas is offline
post #20 of 22 Old 03-07-2007, 03:59 PM Thread Starter
slacker92104
That's great info. I think I have everything I need now. Thx!!!
post #21 of 22 Old 03-07-2007, 05:01 PM
jason m
Nothing but the facts
jason m's Avatar
get some scout inner shafts and cut the chevy outer C's off, cut the chevy 44 tube's down to the scout inner shaft size and re-weld the outer C's, very simple and you use all stock part's. the WMS on the axle will be the same as a scout 57'', get a scout 44 and now you have a matched set of axles front and rear. if you where any closer i would sell you the one i did cheap, if you get a chevy 44 out of a 3/4 ton truck it will most likely have 4.10. mine did and several others that i did before had 4.10, the 1/2 tons axles will have 3.73's. trust me its a easy if you have some simple fab tools and skill's, jason.
jason m is offline
post #22 of 22 Old 03-10-2007, 08:22 PM Thread Starter
slacker92104
I know I can have the chevy shaft shortened, but does anybody know where to get the wagoneer inner shaft for cheap? All I can find are the warn shafts which will cost me more than the whole damn axle.
Chevy 350 vs AMC 360 for CJ swap jc97xj Jeep CJ Forum 22 08-12-2015 09:20 AM
85 CJ-7: chevy 350 - SM465 - Dana 300 anwallac Jeep CJ Forum 21 12-18-2010 07:07 AM
Chevy 350 or 4.3 into CJ5/turbo350/Dana 300, has anyone done this? cbushrun Jeep CJ Forum 20 08-26-2009 04:40 PM
Swapping Chevy Dana 44/12 bolt into a CJ PortlandCJ76 Jeep CJ Forum 0 05-08-2008 04:45 PM
Chevy Dana 44 front axle dawgates Jeep CJ Forum 0 09-07-2005 11:05 AM
