Swap 360 into a cj? - JeepForum.com
post #1 of 5 Old 06-02-2002, 11:25 AM Thread Starter
RustyCJ8
Post Swap 360 into a cj?
I see this can be done(360),but can I swap the 360/t18/d20 into a cj-8?I have the tired old I-6 in there now,as well as the t-176/d300.The tranny and the x-case work fine,but i'd like to swap in all the heavy stuff from the 78 J-20 while i'm at it...Will all this bolt in or...?Thanks
Keep it on all fours.Most of the time anyway..;-)
RustyCJ8 is offline
post #2 of 5 Old 06-02-2002, 12:10 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by RustyCJ8:
<strong>I see this can be done(360),but can I swap the 360/t18/d20 into a cj-8?I have the tired old I-6 in there now,as well as the t-176/d300.The tranny and the x-case work fine,but i'd like to swap in all the heavy stuff from the 78 J-20 while i'm at it...Will all this bolt in or...?Thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Should all work no problem. I believe you will have to change the passenger side motor mount is all.
Steve
OldJeepguy is offline
post #3 of 5 Old 06-02-2002, 04:51 PM
LilRedCJ
Talking
Hey Rusty,
If you move forward with this project, I'd love to take the T-176 off your hands....
'90 Full Bronco
'95 Full Bronco
'85 Jeep CJ 7
Past: '84 Cherokee Chief / '83 CJ 8
LilRedCJ is offline
post #4 of 5 Old 06-02-2002, 09:09 PM
Buff4lo
Post
The AMC 360 fits in w/out a problem. Keep the D300 T-case as it is geared lower than the 20 and strong if not stronger than the 20. Keep the I-6 ignition control module. Not sure on motor mounts but at the most you would need to change the passenger side? Get the mounts from a CJ with a V-8 and they will work. Pull x-tra brackets for the air-pump as these break and keep the factory A/C from a wagoneer 360 to use for compressed air. I would go with an NP435 or NV4500($$) for a tranny and get the advanced adapters kit for the tranny. Of course a T-18 works as well.
1977 CJ-7, D44 corp 20 detroits, D300, NP435, 304, 4" BDS, shackle reversal, 33X12.5 BFG MT's
Buff4lo is offline
post #5 of 5 Old 06-03-2002, 08:57 PM Thread Starter
RustyCJ8
Smile
Thanks for the info,it doesnt sound too bad! Now i've got to get a cherry picker and a motor stand.This will be my 1st motor swap,but i'm pretty sure I can get it done.I'll hold on to the T-176-never know if i'll come across a jeep for cheap!
So the tranny and T-case will bolt right in? or am I dreaming?Pinch me if I am <img border="0" title="" alt="[Eek!]" src="eek.gif" /> (its okay I'm irish
RustyCJ8 is offline
Your opinions: complete 4.0 swap or just 4.0 head swap? '83Laredo Jeep CJ Forum 9 05-22-2011 05:04 AM
Pros and cons of 360 swap versus 304 swap SilverRubiSC Jeep CJ Forum 19 10-12-2009 11:36 PM
yj tub swap on cj TravellinMan_15 Jeep CJ Forum 1 03-29-2009 04:14 PM
Engine swap or engine and transmission swap Notplayn Jeep CJ Forum 3 07-13-2008 07:31 PM
Tranny swap now with future engine swap in mind gestuhlm Jeep CJ Forum 1 04-23-2006 07:49 PM
